Fire-Dragon-DoL
- Dec 22, 2018
Hello!
My setup is the following: 1 vdev with 3 HDDs, all 3 mirror of each other (so 3 x 3TB HDD, total available space = 3TB).
2 Drives are just going to spin all the time, mirror of each other, that's the redundancy. The 3rd drive, I'll plug it in once every now and then (say: once per month) to resilver.
My question is: let's say that all of a sudden the server explodes, killing the 2 HDDs (I have the config in my email), if I restore the config in a new server, do I just need to attach the old device to the pool and it will "resurrect"? What's the correct procedure for restoring backup from a mirror device? Will it cause problem if it's a bit outdated data-wise (but it's the only drive that survived)?
Is this a good approach for backup, or should I just use RSYNC (but that means using a second computer to sync all the data, which is annoying to say the least).
