Hi
TL;DR:
I recently bought a Dell H310 controller card that I managed to flash to IT mode.
I will have a total of 14 drives, I initially planned to have eight of them connected to the motherboard (=maximum) and six connected to the HBA.
The case is however a small-ish tower and thus making the cable management a living hell. It's not a problem once it's set up but I fear that my fat fingers will destroy something when I will need to replace my drives. It would be a tad bit better if I didn't use all sata ports on the MB but I'm not sure if that's a wise move.
I haven't actually found someone who says it happens but some forum threads implies that it's not impossible for the HBA card to wreck the data. If that were to happen now my pool would still be intact but that would not be the case if I filled the HBA´s ports instead of the motherboards. Does anyone have a clear answer if the HBA actually can destroy my data?
(By the way, guess who managed to buy wrong RAM even though I clearly remember doing a double check. I got dimm instead of udimm. So now I have a completely new Freenas system that wont work until I get the right RAM which will take ageeeeeees. At least that's how it will feel. Not my proudest moment...)
TL;DR:
- Can my sas controller card ruin my drives and thus destroying my pool?
- Is there any other drawbacks from using it instead of the sata connections on my motherboard?
- Is there any drawback on having my boot drive on the card instead of the motherboard?
