Hi all,
I am a newbee in TrueNAS. Installed it on HP DL180 G6 server (Pool 2 disks 10Tb each Mirror). Everything works perfect.
However when I decided to use TrueNAS plugin QBittorrent and GDrive cloud credentials (files move from GDrive to TrueNAS) to download data to my datasets I have noticed that the Internet speed connection (optical) between my home network and ISP drops down significantly from around 70-85Mbps to 1.5-6 Mbps (on download) and even my IPTV starts freezing. Upload speed is not affected. When I stop above mentioned services the speed recovers to normal. When I use such services on a PC the speed is not affected at all. I also called to ISP and asked if they use some algorithms to limit the connection speed and the answer was negative. Means this problems occur only on TrueNAS.
Have no idea where to dig. Appreciate any assistance.
