Ok bear with me. I'm lost. Tried to follow the directions.:(:(
I created in my jail the directory
/usr/local/custom/
pkg install devel/libevent2
pkg install wget
wget
https://github.com/tmux/tmux/releases/download/1.9/tmux-1.9.tar.gz
tar xvfz tmux-1.9.tar.gz
cd tmux-1.9
in /usr/local/custom/tmux-1.9/ tar xvfz libevent-2.0.22-stable.tar.gz
./configure && make
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... etc/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking build system type... x86_64-unknown-freebsd9.3
checking host system type... x86_64-unknown-freebsd9.3
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking bitstring.h usability... yes
checking bitstring.h presence... yes
checking for bitstring.h... yes
checking curses.h usability... yes
checking curses.h presence... yes
checking for curses.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for inttypes.h... (cached) yes
checking libutil.h usability... yes
checking libutil.h presence... yes
checking for libutil.h... yes
checking ncurses.h usability... yes
checking ncurses.h presence... yes
checking for ncurses.h... yes
checking ndir.h usability... no
checking ndir.h presence... no
checking for ndir.h... no
checking paths.h usability... yes
checking paths.h presence... yes
checking for paths.h... yes
checking pty.h usability... no
checking pty.h presence... no
checking for pty.h... no
checking for stdint.h... (cached) yes
checking sys/dir.h usability... yes
checking sys/dir.h presence... yes
checking for sys/dir.h... yes
checking sys/ndir.h usability... no
checking sys/ndir.h presence... no
checking for sys/ndir.h... no
checking sys/tree.h usability... yes
checking sys/tree.h presence... yes
checking for sys/tree.h... yes
checking term.h usability... yes
checking term.h presence... yes
checking for term.h... yes
checking util.h usability... no
checking util.h presence... no
checking for util.h... no
checking for gcc that whines about -I... yes
checking for glibc... no
checking for library containing clock_gettime... none required
checking for pkg-config... no
checking for LIBEVENT... no
checking for library containing event_init... no
configure: error: "libevent not found"
root@nzedb_1:/usr/local/custom/tmux-1.9 #
