I am currently doing POC for both TrueNAS SCALE system.
I found that when the SCALE joined domain and set the share to be "Use as Home Share". The domain user cannot access the home share even granted full control for that.
Checked the log show incorrect path or no such directory. It is required to create the user home directory manually using Shell under the share in order to access it.
Meanwhile, SSH enabled the "Allow Kerberos Authentication" and "Allow Password Authentication". Domain administrators group account is unable to login and the log shows unable to find the user.
I did the same setting in latest CORE version. Both are working well. Are the SCALE still working on above two issues? Thanks.
