SOLVED Does Sendmail work?
TooMuchData
I have a script that works in Core and results in sent email. I converted it to run in Scale, and have confirmed that the email file was properly constructed. However, no mail is received.
The /var/log/mail.log contains these lines each time I run the script:
Oct 23 17:31:40 truenas3 find_alias_for_smtplib.py[487888]: sending mail to
To: jeff@redacted
Subject: Status Report for truenas3
MIME-Version: 1.0
Content-T
Any suggestions? Report as bug?
morganL
Captain Morgan
Administrator
Are you running 21.08 or Nightly?
TooMuchData
21.08. Is there a known problem?
from Core cli
echo "Subject: sendmail test" | sendmail -v jeff@redacted
is delivered.
from Scale cli not delivered.
cat /var/log/mail.log =
Oct 24 07:40:39 truenas3 find_alias_for_smtplib.py[1285770]: sending mail to -v, jeff@redacted
truenas3#
morganL
Captain Morgan
Administrator
Not sure, but I'd suggest testing with nightly or waiting for next release on Tuesday. If there is still a problem, report a bug.
There are hundreds of bug fixes in the new version.
TooMuchData
I know the RC arrives tomorrow, but I would test a nightly if I could find them.
marmoset
FWIW sending mail works fine for me, 20.08-beta.2
Just in case, you did set up email in the UI, correct? It's in a super weird place (click on the alert bell in the upper right, hit the setting cog/gear, and select email).
