Hey,
this is actually a documentation bug, regarding the Hardware Recommendation page, and specifically this phrase:
So I suggest either move the link to the right keyword, or just remove it...
It says hot pluggable is not the same as hot swappable (which is of course correct) but on the Hot Pluggable it links to a Hot Swappable explanation :)FreeNAS® supports hot pluggable drives. Make sure that AHCI is enabled in the BIOS. Note that hot plugging is not the same as hot swapping.
