Surely you can describe your problem, steps taken so far, and expected outcome in some detail. You've given everybody very little to actually work with.
Yes with pleasure, etnschuldigugn if it was too little infos.
I set up a Docker image of NGINX on my TRUENAS Scale, with DHCP on port 9999 and then mounted a dataset from a dataset in "/usr/share/nginx/html". That's all I did. In the folder for the website is still an old htaccess file in there, but that should not be a problem, right?
