do not give zfs all your hdd
cloudfire
While building my first FreeNAS I stumbled over this :
http://www.freebsddiary.org/zfs-with-gpart.php
It basically explains, that drive sizes vary and if eg. a 4TB replacement for a defective 4TB HDD has just one block less , than it can not be used since it has to be > or = in size. So the author recommends to use partitions for zfs which are a little smaller than the hdd to be safe.
I can not remember that I would have read about this in any beginners guide here. Are there disadvantages in doing so or is this not a real world problem (and why), or did I just miss it out.
I want to use encryption, is there any problem with underlying partitions ?
wblock
Documentation Engineer
FreeNAS does this by default. Drives are partitioned and have swap space. If encrypted, an encrypted device is created on top of the data partition, then ZFS uses that.
Aside from @wblock noting that FreeNAS already does this by default, this isn't the case, and hasn't been for some time. Drive capacities are standardized--any 4 TB drive will have the same usable capacity, to the byte, as any other 4 TB drive.
USB flash drives, on the other hand... Well, the less said the better.
Vito Reiter
Wise in the Ways of Science
You could do the production environment safe thing and when a drive begins to fail order the same exact drive.
