After updating my truenas from 12.3 to truenas 13.0-U3 and trying to set up a new jail i ran into some connectivity issue where i couldn't acces it through the webgui as i'm used to. While trying to figure out why that happened i reinstalled that jail a couple times, changing 1 thing at a time to try and find the problem, all the while installing packages when needed when suddenly i could no longer install packages in these new jails. Which started a new search through different topics to try and solve that problem which brings me here.
After looking around a bit i found that others have had similar issuess so i tried pinging to see what i could do from inside a freshly made jail.
So it seems to be related to DNS but i haven't touched any DNS settings on that machine while updating. The only change to my knowledge is updating Truenas to it's latest versions some time ago. Checking my global configuration in Network tab i see my Nameserver 1 = 8.8.8.8 and Nameserver 2 = 1.1.1.1 . So since i can ping 8.8.8.8 i would assume it can acces the DNS server and should be able to resolve the pkg.freebsd.org name.
Now i'm stuck as i'm still quite the novice at the OS, basically i've been set it and forget it unless i get notifications in my approach. But now i need help.
root@Temby:~ # pkg update The package management tool is not yet installed on your system. Do you want to fetch and install it now? [y/N]: y Bootstrapping pkg from http://pkg.FreeBSD.org/FreeBSD:13:amd64/quarterly, please wait... pkg: Error fetching http://pkg.FreeBSD.org/FreeBSD:13:amd64/latest/pkg.txz: No address record Address resolution failed for http://pkg.FreeBSD.org/FreeBSD:13:amd64/quarterly. Consider changing PACKAGESITE
root@Temby:~ # ping pkg.freebsd.org ping: Unknown host root@Temby:~ # ping google-public-dns-a.google.com ping: Unknown host root@Temby:~ # ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8): 56 data bytes 64 bytes from 8.8.8.8: icmp_seq=0 ttl=57 time=26.392 ms 64 bytes from 8.8.8.8: icmp_seq=1 ttl=57 time=23.309 ms
