Hey,
I did read posts with similar but not same problems with the Asus C100C. In general I´m a noob any help would be appreciated.
NAS-System: TrueNAS 12 U1 (fresh install) R7 2700/AsRock Rack/64gb Ram/LSI SAS9220-8i (Pool 1 5x8TB), 2x 120 GB SSD (System), 2x1TB NVMe (SSD-Pool), External Drives for Backup, 4TB intern, Asus XG-C100C.
My Network is a consistent Unify network, but I couldn’t bring myself to spend 500€ for the 10GbE Switch. So I want to do what many others have done. Build a peer to peer 10Gbit between NAS and Workstation and leave the rest at 1Gbit for now.
The NAS has 4 Nics. On board: 2x1gbe + 1 for IPMI and an Asus XF-C100C 10 GbE. My Workstation has 1x 1Gbe + 1x C100C 10 GbE.
Problem 1:
How to identify the right Nic. Three Nics are detected and show up in UI (Shouldn’t it be four?). The two 1GbE Nics are recognizable. The third one has no information whatsoever. Just the name ue0. How do I know if that’s the IPMI Nic or the C100C? Couldn’t find information in the shell either. IPMI was detected automatically on the first boot up. So if it is the IPMI Nic. How to enable the C100C?
Problem 2:
Assuming the ue0 is the C100C I gave it a static ip (111.1.1.55/24) the workstation got (111.1.1.56 255.0.0.0 also tried 255.255.255.0 – just in case I did misunderstand the principle). 100% packets loss both ways. The Rest of my Network operates between 192.168.1.1 and 192.168.1.254 usually about 20 Devices with Ips most static. But max. 2 heavy unseres at once.
Thanks in advance,
Bob
Problem 1:
Problem 2:
Thanks in advance,
Bob
