Dismount and Remount Encrypted USB Drive
apolonio
Not sure if this is a bug, still new to FreeNAS, but I am testing out encryption on a USB drive.
I create a new encrypted volume
Then I download the key, filename geli.key and disconnect with a passphrase.
I physically remove the USB disk and then physically reattach it.
I then do an import volume and supply the key and passphrase (funny how it says 1 of 2, then on on next screen it says 2 of 3), I click OK then get an error.
Note with one of the images, I do select da4p2, it is not highlighted in the image.
Here is the error message
Environment:
Software Version: FreeNAS-11.2-RC1 (c831a6a98)
Request Method: POST
Request URL: https://xxxxxxxxxxxxxxx/legacy/storage/auto-import/?X-Progress-ID=1e1066cc-02c2-4299-852e-f37bbb902671
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
  42.			 response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
  249.			 response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
  178.			 response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
  163.		 return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
  23.				 return view_func(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/views/generic/base.py" in view
  68.			 return self.dispatch(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in dispatch
  248.		 response = super(WizardView, self).dispatch(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/views/generic/base.py" in dispatch
  88.		 return handler(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in post
  301.		 if form.is_valid():
File "/usr/local/lib/python3.6/site-packages/django/forms/forms.py" in is_valid
  169.		 return self.is_bound and not self.errors
File "/usr/local/lib/python3.6/site-packages/django/forms/forms.py" in errors
  161.			 self.full_clean()
File "/usr/local/lib/python3.6/site-packages/django/forms/forms.py" in full_clean
  371.		 self._clean_form()
File "/usr/local/lib/python3.6/site-packages/django/forms/forms.py" in _clean_form
  398.			 cleaned_data = self.clean()
File "./freenasUI/storage/forms.py" in clean
  981.			 upload_job_and_wait(key, 'disk.decrypt', disks, passphrase)
File "./freenasUI/middleware/util.py" in upload_job_and_wait
  55.		 return wait_job(c, job_id)
  54.		 job_id = r.json()['job_id']
File "/usr/local/lib/python3.6/site-packages/requests/models.py" in json
  892.		 return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.6/site-packages/simplejson/__init__.py" in loads
  518.		 return _default_decoder.decode(s)
File "/usr/local/lib/python3.6/site-packages/simplejson/decoder.py" in decode
  370.		 obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.6/site-packages/simplejson/decoder.py" in raw_decode
  400.		 return self.scan_once(s, idx=_w(s, idx).end())
Exception Type: JSONDecodeError at /legacy/storage/auto-import/
Exception Value: Expecting value: line 1 column 1 (char 0)
It never mounts, is this a bug?
Am I doing it wrong?
Is there a CLI way to mount?
LA
D
dlavigne
Guest
Please create a report at bugs.freenas.org and post the issue number here.
