Disk Unavailable
lmannyr
I replaced a failing drive.
Ran Short, Long, Conveyence, and badblocks on the replacement disk on a different system; no errors.
In webGUI, followed the manual to take the bad disk out. After the disk was replaced, I put it online/replace etc... It said resilvering process would be started or something to that effect. a couple days has passed and I still have a "DEGRADED" pool with he replacement disk "unavailable".
Smart and zpool status output attached.
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68N32N0
Serial Number:    WD-WCC7K6AF8J4X
LU WWN Device Id: 5 0014ee 2677e76a8
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Oct 14 10:58:17 2020 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (42780) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 454) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x303d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   219   184   021    Pre-fail  Always       -       4041
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       10
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       97
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       10
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       6
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       6
194 Temperature_Celsius     0x0022   118   112   000    Old_age   Always       -       32
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%         9         -
# 2  Conveyance offline  Completed without error       00%         1         -
# 3  Short offline       Completed without error       00%         1         -
# 4  Short offline       Completed without error       00%         1         -
root@Sparrow:~ # zpool status
  pool: BANK
state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
    the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: scrub repaired 0 in 0 days 05:30:23 with 0 errors on Sat Sep 19 05:30:27 2020
    BANK                                            DEGRADED     0     0     0
      raidz2-0                                      DEGRADED     0     0     0
        gptid/a30076fc-7a79-11e5-8637-0cc47a6ae0be  ONLINE       0     0     0
        gptid/a3bebf3c-7a79-11e5-8637-0cc47a6ae0be  ONLINE       0     0     0
        gptid/ed456456-e41f-11e6-9400-0cc47a6ae0be  ONLINE       0     0     0
        3796397183362776384                         UNAVAIL      0     0     0  was /dev/gptid/3f72adff-1dd6-11e9-b2cb-0cc47a6ae0be
        gptid/014298d9-1dd6-11e9-b2cb-0cc47a6ae0be  ONLINE       0     0     0
        gptid/a6b36e4f-7a79-11e5-8637-0cc47a6ae0be  ONLINE       0     0     0
        gptid/a7706d59-7a79-11e5-8637-0cc47a6ae0be  ONLINE       0     0     0
        gptid/a82c560c-7a79-11e5-8637-0cc47a6ae0be  ONLINE       0     0     0
        gptid/a8e7d0ca-7a79-11e5-8637-0cc47a6ae0be  ONLINE       0     0     0
        gptid/00fb152c-210e-11e9-a350-0cc47a6ae0be  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0 days 00:40:02 with 0 errors on Sun Oct 11 04:25:02 2020
    freenas-boot                                    ONLINE       0     0     0
      mirror-0                                      ONLINE       0     0     0
        da8p2                                       ONLINE       0     0     0
        gptid/b9305013-5b3b-11ea-8936-0cc47a6ae0be  ONLINE       0     0     0
Do camcontrol devlist, count your drives, seems you should have 12 devices. Basically I just want to know if there is in fact a missing drive or not.
lmannyr
da1 is the one not working.
camcontrol devlist
<ATA WDC WD40EFRX-68N 0A82>        at scbus0 target 0 lun 0 (pass0,da0)
<ATA WDC WD40EFRX-68N 0A82>        at scbus0 target 1 lun 0 (pass1,da1)
<ATA WDC WD40EFRX-68W 0A82>        at scbus0 target 2 lun 0 (pass2,da2)
<ATA WDC WD40EFRX-68W 0A82>        at scbus0 target 3 lun 0 (pass3,da3)
<ATA WDC WD40EFRX-68W 0A82>        at scbus0 target 4 lun 0 (pass4,da4)
<ATA WDC WD40EFRX-68W 0A82>        at scbus0 target 5 lun 0 (pass5,da5)
<ATA WDC WD40EFRX-68W 0A82>        at scbus0 target 6 lun 0 (pass6,da6)
<ATA WDC WD40EFRX-68W 0A82>        at scbus0 target 7 lun 0 (pass7,da7)
<WDC WD40EFRX-68WT0N0 82.00A82>    at scbus1 target 0 lun 0 (pass8,ada0)
<WDC WD40EFRX-68WT0N0 82.00A82>    at scbus2 target 0 lun 0 (pass9,ada1)
<SanDisk Cruzer Fit 1.27>          at scbus8 target 0 lun 0 (pass10,da8)
<SanDisk Cruzer Fit 1.27>          at scbus9 target 0 lun 0 (pass11,da9)
Says 12. Try running thru the disk replace again.
lmannyr
Using webGUI, I went to pool status to the one disk that says "unavailable" and selected "Online". Then the below changes happened. The disk still shows "unavailable" in the pool status.
FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=11967199016064865894
Oct 18 15:47:16 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=13124258259480360076
Oct 18 15:47:16 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=1031715006901143710
Oct 18 15:47:17 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=3796397183362776384
Oct 18 15:47:17 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=6699592297095300927
Oct 18 15:47:17 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=8958299495562291915
Oct 18 15:47:17 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=685725589415410791
Oct 18 15:47:17 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=2262143812474197006
Oct 18 15:47:17 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=1361399097482395068
Oct 18 15:47:17 FN ZFS: vdev state changed, pool_guid=18188337117115067697 vdev_guid=8321468576493238873
zpool status in ssh... after attempting to ONLINE the disk.
zpool status
  pool: BANK
 state: DEGRADED
  scan: scrub repaired 0 in 0 days 04:58:39 with 0 errors on Thu Oct 15 04:58:43 2020
    BANK                                            DEGRADED     0     0     0
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:27:39 with 0 errors on Sat Oct 17 04:12:39 2020
        da8p2                                       ONLINE       0     0     0
lmannyr
Tried zpool online and zpool replace...
root@FN:~ # zpool online BANK 3796397183362776384
warning: device '3796397183362776384' onlined, but remains in faulted state
use 'zpool replace' to replace devices that are no longer present
root@FN:~ # zpool online BANK /dev/gptid/3f72adff-1dd6-11e9-b2cb-0cc47a6ae0be
warning: device '/dev/gptid/3f72adff-1dd6-11e9-b2cb-0cc47a6ae0be' onlined, but remains in faulted state
