Disk offlined for multiple errors. smartctl doesn't show problem I can understand.
esamett
Is this a cabling error? (new cable needed?) Am I missing something? I replaced the drive and attached with different SATA port. Security report and smartctl reports attached.
I know the drive has lots of hours. But if still "good" I could use as spare.
thanks.
  • security report.txt
  • smartctl report.txt
Chris Moore
For those that might be hesitant to download the files...
smartctl report.txt
root@freenas:~ # smartctl -a /dev/da8 | more
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate Archive HDD
Device Model:     ST8000AS0002-1NA17Z
Serial Number:    Z8407YB6
LU WWN Device Id: 5 000c50 086c962b4
Firmware Version: AR15
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5980 rpm
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Dec  8 19:43:30 2019 CST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (    0) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 953) minutes.
Conveyance self-test routine
SCT capabilities:              (0x30a5) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   118   099   006    Pre-fail  Always       -       170519112
  3 Spin_Up_Time            0x0003   091   090   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       81
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   081   060   030    Pre-fail  Always       -       17723442381
  9 Power_On_Hours          0x0032   061   061   000    Old_age   Always       -       34383
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       63
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       3
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   072   039   045    Old_age   Always   In_the_past 28 (0 90 35 26 0)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       38
193 Load_Cycle_Count        0x0032   070   070   000    Old_age   Always       -       60124
194 Temperature_Celsius     0x0022   028   061   000    Old_age   Always       -       28 (0 18 0 0 0)
195 Hardware_ECC_Recovered  0x001a   118   099   000    Old_age   Always       -       170519112
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       28166 (151 145 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       59060688760
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       2250992433907
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     34380         -
# 2  Extended offline    Aborted by host               90%     34361         -
# 3  Extended offline    Interrupted (host reset)      00%     34361         -
# 4  Short offline       Completed without error       00%     34221         -
# 5  Extended offline    Completed without error       00%     33996         -
# 6  Extended offline    Completed without error       00%     33660         -
# 7  Short offline       Completed without error       00%     33500         -
# 8  Extended offline    Completed without error       00%     33251         -
# 9  Extended offline    Completed without error       00%     32915         -
#10  Short offline       Completed without error       00%     32756         -
#11  Extended offline    Completed without error       00%     32531         -
#12  Extended offline    Completed without error       00%     32195         -
#13  Short offline       Completed without error       00%     32036         -
#14  Extended offline    Completed without error       00%     31787         -
#15  Extended offline    Completed without error       00%     31451         -
#16  Short offline       Completed without error       00%     31292         -
#17  Extended offline    Completed without error       00%     31043         -
#18  Extended offline    Completed without error       00%     30709         -
#19  Short offline       Completed without error       00%     30549         -
#20  Extended offline    Interrupted (host reset)      00%     30518         -
#21  Extended offline    Completed without error       00%     30193         -
root@freenas:~ #
*** FINAL System shutdown message from root@freenas.domain ***
security report.txt
freenas.domain daily security run output
Yahoo
Trash
invasivedoc@gmail.com <invasivedoc@gmail.com>
To:
Dec 2 at 3:01 AM
freenas.domain kernel log messages:
>     (da8:mps0:0:30:0): READ(10). CDB: 28 00 47 cf 9e b8 00 00 08 00 length 4096 SMID 673 terminated ioc 804b loginfo 31110d00 scsi 0 state c xfer 0
>     (da8:mps0:0:30:0): READ(10). CDB: 28 00 47 cf 9a 38 00 00 08 00 length 4096 SMID 568 terminated ioc 804b loginfo 31110d00 scs(da8:mps0:0:30:0): READ(10). CDB: 28 00 47 cf 9e b8 00 00 08 00
> i 0 state c xfer 0
> (da8:mps0:0:30:0): CAM status: CCB request completed with an error
>     (da8:mps0:0:30:0): READ(10). CDB: 28 00 47 cf 97 d8 00 00 08 00 length 4096 SMID 687 terminated ioc 804b loginfo 31110d00 scs(da8:i 0 state c xfer 0
> mps0:0:30:0): Retrying command
> (da8:mps0:0:30:0): Retrying command
> (da8:mps0:0:30:0): CAM status: SCSI Status Error
> (da8:mps0:0:30:0): SCSI status: Check Condition
> (da8:mps0:0:30:0): SCSI sense: NOT READY asc:4,0 (Logical unit not ready, cause not reportable)
> (da8:mps0:0:30:0): Retrying command (per sense data)
> (da8:mps0:0:30:0): Error 5, Retries exhausted
> (da8:mps0:0:30:0): READ(10). CDB: 28 00 47 cf a3 78 00 00 08 00
> (da8:mps0:0:30:0): READ(10). CDB: 28 00 47 cf dd 78 00 00 08 00
> (da8:mps0:0:30:0): READ(10). CDB: 28 00 00 40 02 90 00 00 10 00
> (da8:mps0:0:30:0): READ(10). CDB: 28 00 47 d0 25 58 00 00 08 00
> (da8:mps0:0:30:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 26 90 00 00 00 10 00 00
> (da8:mps0:0:30:0): READ(16). CDB: 88 00 00 00 00 03 a3 81 28 90 00 00 00 10 00 00
> (da8:mps0:0:30:0): READ(10). CDB: 28 00 40 78 65 98 00 00 08 00
> (da8:mps0:0:30:0): READ(10). CDB: 28 00 40 8f 64 18 00 00 08 00
> (da8:mps0:0:30:0): READ(10). CDB: 28 00 40 90 9a 38 00 00 08 00
> (da8:mps0:0:30:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
-- End of security output --
Chris Moore
Just my two cents but the Archive drives have a history of not working well in FreeNAS. While it may be fine in other operating systems, ZFS doesn't appear to like them. They don't come ready fast enough or something.
esamett
aren't .txt files safe? thanks...
Chris Moore
Not saying they are not safe, just that some people might be reluctant to download them. For example, if the user is looking at the forum on a tablet or smart phone.
esamett
They were all I could afford back then. I use them for cool storage only of files that will be read only for the most part. I replaced with the shucked "red-ish" drives on ebay.
