Resilvering done after some 17 hrs.
Still:
Aug 21 13:23:53 freenas smartd[2323]: Device: /dev/ada2, 65535 Currently unreadable (pending) sectors
Aug 21 13:53:53 freenas smartd[2323]: Device: /dev/ada2, 65535 Currently unreadable (pending) sectors
Aug 21 14:23:53 freenas smartd[2323]: Device: /dev/ada2, 65535 Currently unreadable (pending) sectors
The replacement disk isnt brand new, but AFAIK in working condition. WD Green 2TB with flashed firmware (disk idle longer than with stock fw)
[root@freenas] ~# zpool status
pool: vault
state: ONLINE
status: The pool is formatted using a legacy on-disk format. The pool can
still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'. Once this is done, the
pool will no longer be accessible on software that does not support feature
flags.
scan: resilvered 1.42T in 17h58m with 0 errors on Wed Aug 21 14:59:09 2013
NAME STATE READ WRITE CKSUM
vault ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/40597c35-7b28-11e1-98aa-984be10883dd ONLINE 0 0 0
gptid/417ea06a-7b28-11e1-98aa-984be10883dd ONLINE 0 0 0
gptid/5b7e3282-09c2-11e3-9f1c-984be10883dd ONLINE 0 0 0
gptid/87875728-ce05-11e2-ba15-984be10883dd ONLINE 0 0 0
errors: No known data errors
I must admit that this situtiation is a bit over my head. Pool seems healthy, NAS recommends upgrade but it is already version 28 - which is the latest, right?
Whats my next move? And how come zpool command shows cryptic disk names while in GUI they are still ada0... ada3
Smartctl for replacement-drive:
[root@freenas] ~# smartctl -a /dev/ada2
smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Caviar Green (AF)
Device Model: WDC WD20EARS-00MVWB0
Serial Number: WD-WMAZA4472709
LU WWN Device Id: 5 0014ee 058152959
Firmware Version: 51.0AB51
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Wed Aug 21 17:21:39 2013 EEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (37260) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 360) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 244 167 021 Pre-fail Always - 2783
4 Start_Stop_Count 0x0032 092 092 000 Old_age Always - 8034
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 31
9 Power_On_Hours 0x0032 077 077 000 Old_age Always - 16950
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 589
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 497
193 Load_Cycle_Count 0x0032 168 168 000 Old_age Always - 98729
194 Temperature_Celsius 0x0022 107 092 000 Old_age Always - 43
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 001 001 000 Old_age Always - 65535
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
>> is the replacement-disk as good as gone too?
