Athanasios Kakargias
- Dec 11, 2011
I own a HP Microserver and have a zfs raidz1 with 3xWD 2TB drives (WD2003FYYS ) and one just dissapeared...
pool status:
kernel log below:
It didn't show up after a reboot, and I even put it in another bay, as I run it headless, and have no desktop to check the drive, is it safe to assume the drive to be dead?
pool status:
Checking status of zfs pools:
NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT
razor 5.45T 1.72T 3.73T 31% 1.00x DEGRADED /mnt
zingle 464G 420G 44.1G 90% 1.00x ONLINE /mnt
pool: razor
state: DEGRADED
status: One or more devices has been removed by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 0 in 2h4m with 0 errors on Sun Feb 23 07:04:36 2014
NAME STATE READ WRITE CKSUM
razor DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/43deba0c-6cf8-11e3-a53b-3c4a9279bf49 ONLINE 0 0 0
4918402034610113019 REMOVED 0 0 0 was /dev/gptid/9b64c79d-6d98-11e3-889a-3c4a9279bf49
gptid/e5d034f4-6dc5-11e3-9697-3c4a9279bf49 ONLINE 0 0 0
errors: No known data errors
pool: zingle
state: ONLINE
status: One or more devices are configured to use a non-native block size.
Expect reduced performance.
action: Replace affected devices with devices that support the
configured block size, or migrate data to a properly configured
pool.
scan: scrub repaired 0 in 2h3m with 0 errors on Fri Jan 24 07:03:10 2014
zingle ONLINE 0 0 0
ada0 ONLINE 0 0 0 block size: 512B configured, 4096B native
-- End of daily output --
pool: razor
state: DEGRADED
degraded state.
'zpool replace'.
pool: zingle
state: ONLINE
pool.
zingle ONLINE 0 0 0
kernel log below:
micronas.local kernel log messages:
> (ada2:ahcich2:0:0:0): lost device
> swap_pager: I/O error - pagein failed; blkno 928,size 32768, error 6
> vm_fault: pager read error, pid 49380 (Plex Media Server)
> pid 49380 (Plex Media Server), uid 972: exited on signal 11
> cam_periph_alloc: attempt to re-allocate valid device ada2 rejected flags 0x18 refcount 2
> adaasync: Unable to attach to new device due to status 0x6
> (noperiph:ahcich2:0:-1:-1): rescan already queued
-- End of security output --
