Hi all!
Need some help, for sure i miss-config something (hardware detail in signature).
I have installed this spindown timer script, the expected result for me is to let the disk in my StoragePool spindown when not used (and they will be like this 95% of time).
I followed the 2 initial step (configured disk standby settings and System dataset placement as mentioned), then i add a post init script as below
Same result using this command:
The script is placed in the StoragePool, special permission assigned.
What i'm doing wrong? Thanks in advice
but, after like 1 and half our i try this command on shell (found on very old thread):/mnt/StoragePool/Script/SpinDownTimer/spindown_timer.sh -t 3600 -p 600 -m -i ada1 -i ada2
and the disk result spinning (the 10° position is FF).camcontrol cmd ada$ -a "E5 00 00 00 00 00 00 00 00 00 00 00" -r -
the result is idle(0xff).camcontrol epc ada$ -c status -P
