Disc issues, zpool questions.
Joakim Almgren
Hi guys and thanks for a wonderful software.
I would like some help with a few questions if anyone got the time.
I'm pretty new to FreeBSD but know my way around linux.
I run FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty) on 2 boxes with the same setup execpt from the harddrives and it have worked out very well until now.
I have had issues with one disc in this machine before when it ran linux so i susspect its the same one (Not sure yet, but i will try to find my receipt for it to see the serial number)
Anyhow, here's what i want to do and as it is my first time i would like to check with the pro's first.
Replace the broken disc with a new one and resilver.
I did a raid-z setup with 4 3TB discs so that should not be a problem i suppose?, but the zpool is gone and if i do a "zpool list" in a shell it tells me "no pools available"
Whats my next step now to replace the disc?
Here is my error on the disc btw.
GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)usbus0: 12Mbps Full Speed USB v1.0
usbus1: 480Mbps High Speed USB v2.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
usbus4: 12Mbps Full Speed USB v1.0
ugen0.1: <AMD> at usbus0
uhub0: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <AMD> at usbus1
uhub1: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ugen2.1: <AMD> at usbus2
uhub2: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <AMD> at usbus3
uhub3: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
ugen4.1: <AMD> at usbus4
uhub4: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
uhub4: 2 ports with 2 removable, self powered
uhub0: 5 ports with 5 removable, self powered
uhub2: 5 ports with 5 removable, self powered
uhub1: 5 ports with 5 removable, self powered
uhub3: 5 ports with 5 removable, self powered
ugen3.2: <SanDisk> at usbus3
umass0: <SanDisk Cruzer Pattern, class 0/0, rev 2.00/2.00, addr 2> on usbus3
ada0 at ata2 bus 0 scbus0 target 0 lun 0
ada0: <ST3000DM001-9YN166 CC4H> ATA-8 SATA 3.x device
ada0: 33.300MB/s transfers (UDMA2, PIO 8192bytes)
ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ata2 bus 0 scbus0 target 1 lun 0
ada1: <ST3000DM001-9YN166 CC49> ATA-8 SATA 3.x device
ada1: 33.300MB/s transfers (UDMA2, PIO 8192bytes)
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada2 at ata3 bus 0 scbus1 target 0 lun 0
ada2: <ST3000DM001-9YN166 CC4H> ATA-8 SATA 3.x device
ada2: 33.300MB/s transfers (UDMA2, PIO 8192bytes)
ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada3 at ata3 bus 0 scbus1 target 1 lun 0
ada3: <ST3000DM001-9YN166 CC49> ATA-8 SATA 3.x device
ada3: 33.300MB/s transfers (UDMA2, PIO 8192bytes)
ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #1 Launched!
da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
da0: <SanDisk Cruzer Pattern 8.01> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 1908MB (3907711 512 byte sectors: 255H 63S/T 243C)
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
WARNING: /data was not properly dismounted
WARNING: /data: mount pending error: blocks 12 files 2
ZFS filesystem version 5
ZFS storage pool version 28
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:    Crypto: hardware
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: g_eli_read_done() failed ada0p1.eli[READ(offset=2147352576, length=131072)]
GEOM_ELI: g_eli_read_done() failed ada0p1.eli[READ(offset=0, length=131072)]
GEOM_ELI: g_eli_read_done() failed ada0p1.eli[READ(offset=262144, length=131072)]
GEOM_ELI: g_eli_read_done() failed ada0p1.eli[READ(offset=2146959360, length=131072)]
GEOM_ELI: g_eli_read_done() failed ada0p1.eli[READ(offset=2147221504, length=131072)]
[root@freenas] ~#
Kind regards /Joakim
Post the output of zpool status, zpool import, and gpart list to pastebin.
Joakim Almgren
Hello cyberjock.
[root@freenas] ~# zpool status
no pools available
[root@freenas] ~# zpool import
  pool: RAID-Z
  state: DEGRADED
status: One or more devices are missing from the system.
action: The pool can be imported despite missing or damaged devices.  The
    fault tolerance of the pool may be compromised if imported.
  see: http://www.sun.com/msg/ZFS-8000-2Q
    RAID-Z                                          DEGRADED
      raidz1-0                                      DEGRADED
        1144117352227625742                        UNAVAIL  cannot open
        gptid/39c7fa0f-fbae-11e2-a0c0-bc5ff4addedb  ONLINE
        gptid/3a6380cb-fbae-11e2-a0c0-bc5ff4addedb  ONLINE
        gptid/3b02cf62-fbae-11e2-a0c0-bc5ff4addedb  ONLINE
[root@freenas] ~#
[root@freenas] ~# gpart list
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
  Mediasize: 2147483648 (2.0G)
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e1
  rawuuid: 391011e3-fbae-11e2-a0c0-bc5ff4addedb
  rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
  label: (null)
  length: 2147483648
  offset: 65536
  type: freebsd-swap
  index: 1
  end: 4194431
  start: 128
2. Name: ada0p2
  Mediasize: 2998445412352 (2.7T)
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: 3927f605-fbae-11e2-a0c0-bc5ff4addedb
  rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
  label: (null)
  length: 2998445412352
  offset: 2147549184
  type: freebsd-zfs
  index: 2
  end: 5860533127
  start: 4194432
Consumers:
1. Name: ada0
  Mediasize: 3000592982016 (2.7T)
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e2
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e1
  rawuuid: 39b16d4e-fbae-11e2-a0c0-bc5ff4addedb
  label: (null)
  length: 2147483648
  offset: 65536
  type: freebsd-swap
  index: 1
  end: 4194431
  start: 128
2. Name: ada1p2
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: 39c7fa0f-fbae-11e2-a0c0-bc5ff4addedb
  label: (null)
  offset: 2147549184
  type: freebsd-zfs
  index: 2
  end: 5860533127
  start: 4194432
Consumers:
1. Name: ada1
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e2
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e1
  rawuuid: 3a4cc2f4-fbae-11e2-a0c0-bc5ff4addedb
  label: (null)
  length: 2147483648
  offset: 65536
  type: freebsd-swap
  index: 1
  end: 4194431
  start: 128
2. Name: ada2p2
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: 3a6380cb-fbae-11e2-a0c0-bc5ff4addedb
  label: (null)
  offset: 2147549184
  type: freebsd-zfs
  index: 2
  end: 5860533127
  start: 4194432
Consumers:
1. Name: ada2
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r1w1e2
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: 3aeaf019-fbae-11e2-a0c0-bc5ff4addedb
  label: (null)
  length: 2147483648
  offset: 65536
  type: freebsd-swap
  index: 1
  end: 4194431
  start: 128
2. Name: ada3p2
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
  rawuuid: 3b02cf62-fbae-11e2-a0c0-bc5ff4addedb
  label: (null)
  offset: 2147549184
  type: freebsd-zfs
  index: 2
  end: 5860533127
  start: 4194432
Consumers:
1. Name: ada3
  Sectorsize: 512
  Stripesize: 4096
  Stripeoffset: 0
  Mode: r0w0e0
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 3907710
first: 63
entries: 4
scheme: MBR
Providers:
1. Name: da0s1
  Mediasize: 988291584 (942M)
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 32256
  Mode: r1w0e1
  attrib: active
  rawtype: 165
  length: 988291584
  offset: 32256
  type: freebsd
  index: 1
  end: 1930319
  start: 63
2. Name: da0s2
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 988356096
  Mode: r0w0e0
  rawtype: 165
  length: 988291584
  offset: 988356096
  type: freebsd
  index: 2
  end: 3860639
  start: 1930383
3. Name: da0s3
  Mediasize: 1548288 (1.5M)
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 1976647680
  Mode: r0w0e0
  rawtype: 165
  length: 1548288
  offset: 1976647680
  type: freebsd
  index: 3
  end: 3863663
  start: 3860640
4. Name: da0s4
  Mediasize: 21159936 (20M)
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 1978195968
  Mode: r1w1e2
  rawtype: 165
  length: 21159936
  offset: 1978195968
  type: freebsd
  index: 4
  end: 3904991
  start: 3863664
Consumers:
1. Name: da0
  Mediasize: 2000748032 (1.9G)
  Sectorsize: 512
  Mode: r2w1e4
Geom name: da0s1
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 1930256
first: 0
entries: 8
scheme: BSD
Providers:
1. Name: da0s1a
  Mediasize: 988283392 (942M)
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 40448
  Mode: r1w0e1
  rawtype: 0
  length: 988283392
  offset: 8192
  type: !0
  index: 1
  end: 1930256
  start: 16
Consumers:
1. Name: da0s1
  Sectorsize: 512
  Stripesize: 0
  Stripeoffset: 32256
  Mode: r1w0e1
[root@freenas] ~#
Well, it looks like your drives are all detected, and the partitions and such are there.
How about smartctl -a -q noserial /dev/ada0
Joakim Almgren
[root@freenas] ~# smartctl -a -q noserial /dev/ada0
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
(pass0:ata2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 01 00
(pass0:ata2:0:0:0): CAM status: ATA Status Error
(pass0:ata2:0:0:0): ATA status: 71 (DRDY DF SERV ERR), error: 04 (ABRT )
(pass0:ata2:0:0:0): RES: 71 04 00 00 00 00 00 00 00 01 00
(pass0:ata2:0:0:0): ATAPI_IDENTIFY. ACB: a1 00 00 00 00 40 00 00 00 00 01 00
Smartctl: Device Read Identity Failed: Unknown error
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options
Ok.. so that drive is definitely having problems. Try shutting down the server so it powers off, wait 30 seconds, power it back up and run that smartctl command again. Hopefully the drive will work just long enough to get a different output.
Joakim Almgren
Hi again, I've tried 3 times now without luck, anyhow.. I dont really care about this disc as it has haunted me for 2 years :mad:
Is it possible to remove it and replace it with a new and resilver?
Sure! Follow the FreeNAS manual for disk replacement. ;)
It's very simple and easy. And if you do every step, in order, just like its written, you'll have no problems.
I will warn you that with RAIDZ1 you have no redundancy. So replacing the failed disk should be your top priority right now. If you don't replace it and another disk starts having problems, you may lose your entire pool.
Joakim Almgren
Excuse me if this is a dumb question but you mean that i dont have any redundancy NOW, as one of the disc is out?
When the pool was intact and working it was allright if one disc failed, i just replace it with another one? almost as raid5 right?
radiz2 maybe would be better, if one disc fails as i resilver im lost right?
Anyhow, I will replace the broken disc next weekend, following the tutorial and the pool with my data will work again yes?
Thanks /Joakim
You are correct with everything you said.
You have no redundancy. Even a single sector failure on one of your remaining disks could spell disaster. It's happened, frequently. That's why I've got the "RAID5 is dead" link in my sig. The risk is enormous while rebuilding the pool. You stress the disks during rebuilds, so its a very inopportune time for things to go bad.
Joakim Almgren
I see, bad choice from the start with other words.
But i dont see any other choice right now, or do you have any smart suggestion that would help me from my cousin (wich owns the box) strangles me if the resilver fails?
Is it possible to mount a part of a pool and copy the most important data from it or maybe remove the broken disc to another computer hoping it will start there and do an image of that disc with dd and write that to another 3TB disc?
The pool should be mounting and working right now. Is it not still auto-mounting? Normally, if the pool is listed in the GUI it should be trying to mount it. If it's not mounting, then you may have problems.
If things aren't mounting you should be able to use the auto-import feature to import the pool.
You can't resilver the missing drive without the pool being mounted, so if the pool isn't in a condition where it is mountable, then you have bigger problems than just a failed disk.
Joakim Almgren
Oh my :)
No its not mounting anything, and I cant import as the status of the pool is unknown.
Yeah, UNKNOWN is the normal output when a pool isn't mounted. No cause for alarm there.
But if it's not mounting now, that's a bad thing!
Try this command:
zpool import -R /mnt RAID-Z
Joakim Almgren
Before i try that, try to make sense of this crazy thing that just happened as i am totally lost.
I did a restart and tried some smartctl -a on ada0 again and it worked, i got the info and no errors.
Model Family:    Seagate Barracuda (SATA 3Gb/s, 4K Sectors)
Device Model:    ST3000DM001-9YN166
Serial Number:    Z1F0DQ67
LU WWN Device Id: 5 000c50 03f84db2f
Firmware Version: CC49
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:    512 bytes logical, 4096 bytes physical
ATA Version is:  8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Fri Feb 21 15:45:49 2014 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      (  0)    The previous self-test routine completed
                    been run.
data collection:        (  584) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (  1) minutes.
Extended self-test routine
recommended polling time:      ( 342) minutes.
Conveyance self-test routine
recommended polling time:      (  2) minutes.
SCT capabilities:            (0x3085)    SCT Status supported.
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate    0x000f  109  099  006    Pre-fail  Always      -      23685032
  3 Spin_Up_Time            0x0003  092  092  000    Pre-fail  Always      -      0
  4 Start_Stop_Count        0x0032  100  100  020    Old_age  Always      -      115
  5 Reallocated_Sector_Ct  0x0033  100  100  036    Pre-fail  Always      -      0
  7 Seek_Error_Rate        0x000f  073  060  030    Pre-fail  Always      -      8632291987
  9 Power_On_Hours          0x0032  081  081  000    Old_age  Always      -      17276
10 Spin_Retry_Count        0x0013  100  100  097    Pre-fail  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  020    Old_age  Always      -      126
183 Runtime_Bad_Block      0x0032  081  081  000    Old_age  Always      -      19
184 End-to-End_Error        0x0032  100  100  099    Old_age  Always      -      0
187 Reported_Uncorrect      0x0032  100  100  000    Old_age  Always      -      0
188 Command_Timeout        0x0032  100  095  000    Old_age  Always      -      51540918301
189 High_Fly_Writes        0x003a  094  094  000    Old_age  Always      -      6
190 Airflow_Temperature_Cel 0x0022  063  050  045    Old_age  Always      -      37 (Min/Max 32/37)
191 G-Sense_Error_Rate      0x0032  100  100  000    Old_age  Always      -      0
192 Power-Off_Retract_Count 0x0032  100  100  000    Old_age  Always      -      97
193 Load_Cycle_Count        0x0032  090  090  000    Old_age  Always      -      20961
194 Temperature_Celsius    0x0022  037  050  000    Old_age  Always      -      37 (0 17 0 0 0)
197 Current_Pending_Sector  0x0012  100  100  000    Old_age  Always      -      0
198 Offline_Uncorrectable  0x0010  100  100  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x003e  200  199  000    Old_age  Always      -      19
240 Head_Flying_Hours      0x0000  100  253  000    Old_age  Offline      -      12511239739450
241 Total_LBAs_Written      0x0000  100  253  000    Old_age  Offline      -      224820338867489
242 Total_LBAs_Read        0x0000  100  253  000    Old_age  Offline      -      70239342043644
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error      00%    11835        -
# 2  Short offline      Completed without error      00%    11829        -
# 3  Short offline      Completed without error      00%    11805        -
# 4  Short offline      Completed without error      00%    11781        -
# 5  Short offline      Completed without error      00%    11757        -
# 6  Short offline      Completed without error      00%    11733        -
# 7  Short offline      Completed without error      00%    11709        -
# 8  Short offline      Completed without error      00%    11685        -
# 9  Extended offline    Completed without error      00%    11667        -
#10  Short offline      Completed without error      00%    11661        -
#11  Short offline      Completed without error      00%    11637        -
#12  Short offline      Completed without error      00%    11613        -
#13  Short offline      Completed without error      00%    11588        -
#14  Short offline      Completed without error      00%    11564        -
#15  Short offline      Completed without error      00%    11540        -
#16  Short offline      Completed without error      00%    11516        -
#17  Extended offline    Completed without error      00%    11499        -
#18  Short offline      Completed without error      00%    11492        -
#19  Short offline      Completed without error      00%    11468        -
#20  Short offline      Completed without error      00%    11444        -
#21  Short offline      Completed without error      00%    11420        -
[root@freenas] ~#
However! ada3 is now gone, do i smell more hardware issues or do i have to call ghost busters for this one? :)
[root@freenas] ~# dmesg | grep ada
ada0 at ata2 bus 0 scbus0 target 1 lun 0
ada0: <ST3000DM001-9YN166 CC49> ATA-8 SATA 3.x device
ada1 at ata3 bus 0 scbus1 target 0 lun 0
ada1: <ST3000DM001-9YN166 CC4H> ATA-8 SATA 3.x device
ada2 at ata3 bus 0 scbus1 target 1 lun 0
ada2: <ST3000DM001-9YN166 CC49> ATA-8 SATA 3.x device
[root@freenas] ~#
Can I suspect the ram or maybe even the motherboard?
I know there was 2 files on the ZFS pool that was corrupt, (moved to FreeNAS corrupted from another filesystem) could that be an issue, with bad checksums or something like that?
Well, if the old ada0 is no longer being detected, then the old ada1 would be ada0. Notice you had ada0 through ada3, now you have ada0 through ada2. That's why you should never label your disks with stickers that say "ada0". They can change in an instant. Basically, it looks like you have no way of proving the status of the old disk, and should give up trying to troubleshoot it further. It's very broken.
Previously corrupted files will simply be checksumed in their current state. The checksums will only find new corruption if it exists since you've put the files on ZFS.
Joakim Almgren
Aha yes ofcourse, well then...
[root@freenas] ~# zpool import -R /mnt RAID-Z
cannot import 'RAID-Z': I/O error
    Destroy and re-create the pool from
    a backup source.
[root@freenas] ~#
Yeah.. sounds like you had some corruption somewhere, and now that you lost one drive, it's gone.
See that link in my sig? Lost pools like yours are precisely why I have that in my signature. ;)
Can you post the smart data for the rest of your disks? And your hardware specs? Curious to see how your system went to crap so fast. Surely you've made other errors besides just a failed RAIDZ1 disk.
Edit: Situations like this are precisely why I offer my services via paypal. Almost everyone that is new to FreeNAS makes more than 1 mistake, and almost always have more than 1 serious mistake. So pools that appear to have redundancy may not be as reliable as people think because of those mistakes. It's too bad too, for most people, they'd consider it money very well spent to ensure they aren't a statistic. But hey, everyone is here for the "Free" in FreeNAS, so I shouldn't be surprised.
Joakim Almgren
This will be awesome to tell my cousin, like a trip on lsd. :eek:
"Hello, all your data is poop, GOODBYE!"
Maybe if i send the 3 working drives to a company that is specialized in retriving data?
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p7 #1 r249203M: Sat Apr  6 09:28:27 PDT 2013
    root@build.ixsystems.com:/tank/home/jpaetzel/fn8.3/freenas/os-base/amd64/tank/home/jpaetzel/fn8.3/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD A4-4000 APU with Radeon(tm) HD Graphics    (2994.57-MHz K8-class CPU)
  Origin = "AuthenticAMD"  Id = 0x610f31  Family = 15  Model = 13  Stepping = 1
  Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
  Features2=0x3698320b<SSE3,PCLMULQDQ,MON,SSSE3,FMA,CX16,SSE4.1,SSE4.2,POPCNT,AESNI,XSAVE,AVX,F16C>
  AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
  AMD Features2=0x1ebbfff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,XOP,SKINIT,WDT,LWP,FMA4,<b17>,NodeId,TBM,Topology,<b23>,<b24>>
  TSC: P-state invariant
real memory  = 17179869184 (16384 MB)
avail memory = 15939059712 (15200 MB)
ACPI APIC Table: <ALASKA A M I>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID: 16
cpu1 (AP): APIC ID: 17
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20101013/tbfadt-655)
ioapic0 <Version 2.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Apr  6 2013 09:28:15)
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
acpi0: <ALASKA A M I> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0xf000-0xf0ff mem 0xc0000000-0xcfffffff,0xff700000-0xff73ffff irq 17 at device 1.0 on pci0
pci0: <multimedia, HDA> at device 1.1 (no driver attached)
pci0: <serial bus, USB> at device 16.0 (no driver attached)
pci0: <serial bus, USB> at device 16.1 (no driver attached)
atapci0: <AMD ATA controller> port 0xf190-0xf197,0xf180-0xf183,0xf170-0xf177,0xf160-0xf163,0xf150-0xf15f mem 0xff751000-0xff7517ff irq 19 at device 17.0 on pci0
atapci0: [ITHREAD]
ata2: <ATA channel> at channel 0 on atapci0
ata2: [ITHREAD]
ata3: <ATA channel> at channel 1 on atapci0
ata3: [ITHREAD]
ohci0: <OHCI (generic) USB controller> mem 0xff750000-0xff750fff irq 18 at device 18.0 on pci0
ohci0: [ITHREAD]
usbus0: <OHCI (generic) USB controller> on ohci0
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xff74f000-0xff74f0ff irq 17 at device 18.2 on pci0
ehci0: [ITHREAD]
usbus1: EHCI version 1.0
usbus1: <EHCI (generic) USB 2.0 controller> on ehci0
ohci1: <OHCI (generic) USB controller> mem 0xff74e000-0xff74efff irq 18 at device 19.0 on pci0
ohci1: [ITHREAD]
usbus2: <OHCI (generic) USB controller> on ohci1
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xff74d000-0xff74d0ff irq 17 at device 19.2 on pci0
ehci1: [ITHREAD]
usbus3: EHCI version 1.0
usbus3: <EHCI (generic) USB 2.0 controller> on ehci1
pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
atapci1: <AMD ATA controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xf100-0xf10f at device 20.1 on pci0
ata0: <ATA channel> at channel 0 on atapci1
ata0: [ITHREAD]
ata1: <ATA channel> at channel 1 on atapci1
ata1: [ITHREAD]
pci0: <multimedia, HDA> at device 20.2 (no driver attached)
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib1: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci1: <ACPI PCI bus> on pcib1
ohci2: <OHCI (generic) USB controller> mem 0xff74c000-0xff74cfff irq 18 at device 20.5 on pci0
ohci2: [ITHREAD]
usbus4: <OHCI (generic) USB controller> on ohci2
pcib2: <ACPI PCI-PCI bridge> at device 21.0 on pci0
pci2: <ACPI PCI bus> on pcib2
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F PCIe Gigabit Ethernet> port 0xe000-0xe0ff mem 0xd0004000-0xd0004fff,0xd0000000-0xd0003fff irq 16 at device 0.0 on pci2
re0: Using 1 MSI-X message
re0: Chip rev. 0x2c800000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0:  none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: bc:5f:f4:ad:de:db
re0: [ITHREAD]
acpi_button0: <Power Button> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
ppc0: cannot reserve I/O port range
acpi_throttle0: <ACPI CPU Throttling> on cpu0
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
acpi_throttle1: <ACPI CPU Throttling> on cpu1
acpi_throttle1: failed to attach P_CNT
device_attach: acpi_throttle1 attach returned 6
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
hpt27xx: no controller detected.
[root@freenas] ~#
[root@freenas] ~# smartctl -a /dev/ada
ada0%      ada0p1%    ada0p1.eli% ada0p2%    ada1%      ada1p1%    ada1p1.eli% ada1p2%    ada2%      ada2p1%    ada2p1.eli% ada2p2%
[root@freenas] ~# smartctl -a /dev/ada0
ATA Version is:  8
Local Time is:    Fri Feb 21 16:43:27 2014 CET
                    been run.
                    command.
                    power-saving mode.
  1 Raw_Read_Error_Rate    0x000f  109  099  006    Pre-fail  Always      -      24115560
  7 Seek_Error_Rate        0x000f  073  060  030    Pre-fail  Always      -      8632292206
  9 Power_On_Hours          0x0032  081  081  000    Old_age  Always      -      17277
190 Airflow_Temperature_Cel 0x0022  064  050  045    Old_age  Always      -      36 (Min/Max 32/37)
194 Temperature_Celsius    0x0022  036  050  000    Old_age  Always      -      36 (0 17 0 0 0)
240 Head_Flying_Hours      0x0000  100  253  000    Old_age  Offline      -      251487515056187
241 Total_LBAs_Written      0x0000  100  253  000    Old_age  Offline      -      224820338868065
242 Total_LBAs_Read        0x0000  100  253  000    Old_age  Offline      -      70239342224850
No Errors Logged
[root@freenas] ~#
[root@freenas] ~# smartctl -a /dev/ada1
Serial Number:    Z1F0EFZ4
LU WWN Device Id: 5 000c50 03f8540f4
Firmware Version: CC4H
ATA Version is:  8
Local Time is:    Fri Feb 21 16:44:00 2014 CET
                    been run.
data collection:        (  575) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 334) minutes.
  1 Raw_Read_Error_Rate    0x000f  115  099  006    Pre-fail  Always      -      100104168
  4 Start_Stop_Count        0x0032  100  100  020    Old_age  Always      -      232
  5 Reallocated_Sector_Ct  0x0033  100  100  036    Pre-fail  Always      -      160
  7 Seek_Error_Rate        0x000f  069  060  030    Pre-fail  Always      -      30131990721
  9 Power_On_Hours          0x0032  084  084  000    Old_age  Always      -      14081
12 Power_Cycle_Count      0x0032  100  100  020    Old_age  Always      -      234
183 Runtime_Bad_Block      0x0032  071  071  000    Old_age  Always      -      29
188 Command_Timeout        0x0032  100  098  000    Old_age  Always      -      42950524941
189 High_Fly_Writes        0x003a  096  096  000    Old_age  Always      -      4
192 Power-Off_Retract_Count 0x0032  100  100  000    Old_age  Always      -      199
193 Load_Cycle_Count        0x0032  084  084  000    Old_age  Always      -      33851
199 UDMA_CRC_Error_Count    0x003e  200  198  000    Old_age  Always      -      229
240 Head_Flying_Hours      0x0000  100  253  000    Old_age  Offline      -      165545219467445
241 Total_LBAs_Written      0x0000  100  253  000    Old_age  Offline      -      72017933670207
242 Total_LBAs_Read        0x0000  100  253  000    Old_age  Offline      -      67049844825406
No Errors Logged
# 1  Extended offline    Completed without error      00%      8589        -
# 2  Short offline      Completed without error      00%      8582        -
# 3  Short offline      Completed without error      00%      8558        -
# 4  Short offline      Completed without error      00%      8534        -
# 5  Short offline      Completed without error      00%      8510        -
# 6  Short offline      Completed without error      00%      8486        -
# 7  Short offline      Completed without error      00%      8462        -
# 8  Short offline      Completed without error      00%      8438        -
# 9  Extended offline    Completed without error      00%      8422        -
#10  Short offline      Completed without error      00%      8414        -
#11  Short offline      Completed without error      00%      8390        -
#12  Short offline      Completed without error      00%      8366        -
#13  Short offline      Completed without error      00%      8342        -
#14  Short offline      Completed without error      00%      8318        -
#15  Short offline      Completed without error      00%      8294        -
#16  Short offline      Completed without error      00%      8270        -
#17  Extended offline    Completed without error      00%      8253        -
#18  Short offline      Completed without error      00%      8246        -
#19  Short offline      Completed without error      00%      8222        -
#20  Short offline      Completed without error      00%      8198        -
#21  Short offline      Completed without error      00%      8174        -
[root@freenas] ~#
[root@freenas] ~# smartctl -a /dev/ada2
Serial Number:    Z1F0DPM9
LU WWN Device Id: 5 000c50 03f84fb57
ATA Version is:  8
Local Time is:    Fri Feb 21 16:44:22 2014 CET
                    been run.
                    command.
                    power-saving mode.
  1 Raw_Read_Error_Rate    0x000f  110  099  006    Pre-fail  Always      -      28380008
  4 Start_Stop_Count        0x0032  100  100  020    Old_age  Always      -      114
  7 Seek_Error_Rate        0x000f  070  060  030    Pre-fail  Always      -      8613621049
  9 Power_On_Hours          0x0032  081  081  000    Old_age  Always      -      17304
12 Power_Cycle_Count      0x0032  100  100  020    Old_age  Always      -      121
183 Runtime_Bad_Block      0x0032  078  078  000    Old_age  Always      -      22
188 Command_Timeout        0x0032  100  098  000    Old_age  Always      -      8590196741
189 High_Fly_Writes        0x003a  100  100  000    Old_age  Always      -      0
190 Airflow_Temperature_Cel 0x0022  066  054  045    Old_age  Always      -      34 (Min/Max 30/34)
192 Power-Off_Retract_Count 0x0032  100  100  000    Old_age  Always      -      89
193 Load_Cycle_Count        0x0032  087  087  000    Old_age  Always      -      27868
194 Temperature_Celsius    0x0022  034  046  000    Old_age  Always      -      34 (0 16 0 0 0)
240 Head_Flying_Hours      0x0000  100  253  000    Old_age  Offline      -      242717191837845
241 Total_LBAs_Written      0x0000  100  253  000    Old_age  Offline      -      261588573394194
242 Total_LBAs_Read        0x0000  100  253  000    Old_age  Offline      -      42607825108936
No Errors Logged
# 1  Extended offline    Completed without error      00%    11859        -
# 2  Short offline      Completed without error      00%    11853        -
# 3  Short offline      Completed without error      00%    11829        -
# 4  Short offline      Completed without error      00%    11805        -
# 5  Short offline      Completed without error      00%    11781        -
# 6  Short offline      Completed without error      00%    11757        -
# 7  Short offline      Completed without error      00%    11733        -
# 8  Short offline      Completed without error      00%    11709        -
# 9  Extended offline    Completed without error      00%    11691        -
#10  Short offline      Completed without error      00%    11685        -
#11  Short offline      Completed without error      00%    11661        -
#12  Short offline      Completed without error      00%    11637        -
#13  Short offline      Completed without error      00%    11613        -
#14  Short offline      Completed without error      00%    11589        -
#15  Short offline      Completed without error      00%    11565        -
#16  Short offline      Completed without error      00%    11541        -
#17  Extended offline    Completed without error      00%    11523        -
#18  Short offline      Completed without error      00%    11517        -
#19  Short offline      Completed without error      00%    11493        -
#20  Short offline      Completed without error      00%    11469        -
#21  Short offline      Completed without error      00%    11445        -
[root@freenas] ~#
