Yes. Your bottleneck isn't network but your storage system.If you have SAN network on 10Gb , would you go without jumbo ?
We out here live in a budget. The hbas that I use at work cost more then my entire freenas system. And they are connected to a San that cost more than my house. As to the speed I was assuming spinning disk not SSD. But if 10gig isn't fast enough you can always go 40gig.My info might be outdated, but when I read whitepapers from enterprise equipment vendors, they kind of expect you to use jumbo in 10Gb SAN network. Same way they expect that if you have iSCSI on isolated storage network.
P.S. I don't claim to be right, I rather learn.![]()
Your 9Gb/s sounds good, what is the hardware ? and the nics ?
11.1What about the freenas version you are using ?
I have no device(at the moment) that is configured to use jumbo frames. So nobody is sending jumbo frames from the clients. But the question is: If jumbo is enable or disabled on switch how that will effect anything ?!
Freenas nic: mellonox mcx-311a
Asrock E3224-4L E3-1220 V3 32gb
VM server nic: mellonox mcx-312a
Supermicro X10SLL-F E3-1220 V3 16gb
Switch: css-326
Dac 2m cable
Connected using Ubuntu 16 in a vm on xenserver 7.3.
You really got all the juice from the mellonox cards :)
I am just curious , why you have these two connected like that ?
One is file server , that's fine , but other is not a workstation?! It's a ubuntu VM on Xen hyper-visor ?
I am just wandering what kind of setup is that and what purpose is serving ?
