Hi All,
I have some seagate sas drive that I want to disable the disk's "background scan" as ZFS does what I want. In one host I see 24 drives with this feature on and 24 with it off. I would rather have it off.
In Linux:
# view the current values for the background media settings
sdparm /dev/sdb -p bc
# enable Background Media scans - set to 0 to disable
sdparm /dev/sdb -p bc -s EN_BMS=1
# number of hours between media scans - here, run a scan every 24 hours
sdparm /dev/sdb -p bc -s BMS_I=24
# how many milliseconds the drive must be idle before a scan can begin
# here, the drive must be idle for two second at time of scan start,
# or else the scan will wait until the drive is idle for 2000ms.
# the same applies if scan is interrupted for user activity - scan resumes when
# this period of time has elapsed with no activity.
sdparm /dev/sdb -p bc -s MIN_IDLE=2000
# how many milliseconds the drive is permitted to take to return to regular service
# if a command is received during a background media scan - here, the drive must
# stop the BMS within 500ms of receiving a read/write command from the host
sdparm /dev/sdb -p bc -s MAX_SUSP=500
Thanks,
Joe
In Linux:
Thanks,
Joe
