Directory Services Active Directory
rafaeljrssg
I am unable to activate Active Directory on my truenas.
The problem seems to have occurred after some update.
When I check the checkbox, the system should display some fields below for me to enter the username and password, but this does not occur.
Does anyone know another way to join the machine to the domain?
rafaeljrssg
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/activedirectory.py", line 797, in validate_credentials
self.middleware.call_sync('kerberos.do_kinit', data)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1264, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1304, in run_coroutine
return fut.result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 438, in result
return self.__get_result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 390, in __get_result
raise self._exception
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/kerberos.py", line 269, in do_kinit
raise CallError(f"kinit for domain [{data['domainname']}] "
middlewared.service_exception.CallError: [EFAULT] kinit for domain [VIPTECNOLOGIA.LOCAL] with principal [TRUENAS$@VIPTECNOLOGIA.LOCAL] failed: kinit: Password incorrect
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/activedirectory.py", line 535, in do_update
await self.middleware.run_in_thread(self.validate_credentials, new)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/activedirectory.py", line 799, in validate_credentials
realm = self.middleware.call_sync(
return fut.result()
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 474, in query
return await self.middleware.run_in_thread(
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/__init__.py", line 203, in filter_list
raise MatchNotFound()
middlewared.service_exception.MatchNotFound
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 138, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1205, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 376, in update
rv = await self.middleware._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/activedirectory.py", line 537, in do_update
raise ValidationError(
middlewared.service_exception.ValidationError: [EFAULT] activedirectory_update.bindpw: Failed to validate bind credentials:
