MarkEWaite
- Sep 24, 2018
I have a plex jail running on my FreeNAS Mini XL running FreeNAS-11.1-U6.
When I restart the hardware (after an operating system upgrade, etc.), the plex server is unable to find the media that I had previously uploaded.
When I restart the plex jail, without restarting the hardware, the plex server is able to find the media that I have previously uploaded.
I lack FreeNAS skills and have been unable to diagnose the problem. The workaround (restart the plex jail once after each hardware restart) is easy and simple. I would like to understand why the problem occurs and how to resolve it. It is not a rush to understand it, but I would like to understand it.
When the plex server is able to find the media, the output of
When the plex server is not able to find the media, the output of
In the failing case, there is an extra mount point pool-a/jails/plexmediaserver_1/plex-media. Could that be hiding the real data behind that incorrect mount point?
Where should I look to find the definition of that mount point so that I can try removing the mount point?
Are there other things I should check?
Mark Waite
df
run from the root shell opened from the FreeNAS web interface is:Code:
[root@freenas ~]# df Filesystem 512-blocks Used Avail Capacity Mounted on freenas-boot/ROOT/11.1-U6 20317840 2324776 17993064 11% / devfs 2 2 0 100% /dev tmpfs 65536 21288 44248 32% /etc tmpfs 8192 16 8176 0% /mnt tmpfs 22325328 166632 22158696 1% /var freenas-boot/grub 18009072 16008 17993064 0% /boot/grub fdescfs 2 2 0 100% /dev/fd pool-a 11158025864 317261088 10840764776 3% /mnt/pool-a pool-a/Data 10840765024 248 10840764776 0% /mnt/pool-a/Data pool-a/jails 10840800392 35616 10840764776 0% /mnt/pool-a/jails pool-a/jails/.warden-template-pluginjail-10.3-x64 10841725552 960776 10840764776 0% /mnt/pool-a/jails/.warden-template-pluginjail-10.3-x64 pool-a/jails/.warden-template-standard-10.3-x64 10844145720 3380944 10840764776 0% /mnt/pool-a/jails/.warden-template-standard-10.3-x64 pool-a/jails/git-server 10911555272 70790496 10840764776 1% /mnt/pool-a/jails/git-server pool-a/jails/plexmediaserver_1 14498222456 3657457680 10840764776 25% /mnt/pool-a/jails/plexmediaserver_1 pool-a/.system 10840764968 192 10840764776 0% /var/db/system pool-a/.system/cores 10840768120 3344 10840764776 0% /var/db/system/cores pool-a/.system/samba4 10840766136 1360 10840764776 0% /var/db/system/samba4 pool-a/.system/syslog-618a7bc26f3c409faab2b82ca8892702 10840775616 10840 10840764776 0% /var/db/system/syslog-618a7bc26f3c409faab2b82ca8892702 pool-a/.system/rrd-618a7bc26f3c409faab2b82ca8892702 10840815520 50744 10840764776 0% /var/db/system/rrd-618a7bc26f3c409faab2b82ca8892702 pool-a/.system/configs-618a7bc26f3c409faab2b82ca8892702 10840865552 100776 10840764776 0% /var/db/system/configs-618a7bc26f3c409faab2b82ca8892702 devfs 2 2 0 100% /mnt/pool-a/jails/git-server/dev procfs 8 8 0 100% /mnt/pool-a/jails/git-server/proc devfs 2 2 0 100% /mnt/pool-a/jails/plexmediaserver_1/dev procfs 8 8 0 100% /mnt/pool-a/jails/plexmediaserver_1/proc /mnt/pool-a/jails/plexmediaserver_1/plex-media 14498222456 3657457680 10840764776 25% /mnt/pool-a/jails/plexmediaserver_1/home/plex-media [root@freenas ~]#
df
[root@freenas ~]# df Filesystem 512-blocks Used Avail Capacity Mounted on freenas-boot/ROOT/11.1-U6 20317888 2324776 17993112 11% / devfs 2 2 0 100% /dev tmpfs 65536 21288 44248 32% /etc tmpfs 8192 16 8176 0% /mnt tmpfs 22325328 50976 22274352 0% /var freenas-boot/grub 18009120 16008 17993112 0% /boot/grub fdescfs 2 2 0 100% /dev/fd pool-a 11204306800 317261088 10887045712 3% /mnt/pool-a pool-a/Data 10887045960 248 10887045712 0% /mnt/pool-a/Data pool-a/jails 10887081328 35616 10887045712 0% /mnt/pool-a/jails pool-a/jails/.warden-template-pluginjail-10.3-x64 10888006488 960776 10887045712 0% /mnt/pool-a/jails/.warden-template-pluginjail-10.3-x64 pool-a/jails/.warden-template-standard-10.3-x64 10890426656 3380944 10887045712 0% /mnt/pool-a/jails/.warden-template-standard-10.3-x64 pool-a/jails/git-server 10957836064 70790352 10887045712 1% /mnt/pool-a/jails/git-server pool-a/jails/plexmediaserver_1 14498196416 3611150704 10887045712 25% /mnt/pool-a/jails/plexmediaserver_1 pool-a/jails/plexmediaserver_1/plex-media 11018447720 131402008 10887045712 1% /mnt/pool-a/jails/plexmediaserver_1/plex-media pool-a/.system 10887045904 192 10887045712 0% /var/db/system pool-a/.system/cores 10887074152 28440 10887045712 0% /var/db/system/cores pool-a/.system/samba4 10887047032 1320 10887045712 0% /var/db/system/samba4 pool-a/.system/syslog-618a7bc26f3c409faab2b82ca8892702 10887056616 10904 10887045712 0% /var/db/system/syslog-618a7bc26f3c409faab2b82ca8892702 pool-a/.system/rrd-618a7bc26f3c409faab2b82ca8892702 10887096464 50752 10887045712 0% /var/db/system/rrd-618a7bc26f3c409faab2b82ca8892702 pool-a/.system/configs-618a7bc26f3c409faab2b82ca8892702 10887146488 100776 10887045712 0% /var/db/system/configs-618a7bc26f3c409faab2b82ca8892702 devfs 2 2 0 100% /mnt/pool-a/jails/git-server/dev procfs 8 8 0 100% /mnt/pool-a/jails/git-server/proc devfs 2 2 0 100% /mnt/pool-a/jails/plexmediaserver_1/dev procfs 8 8 0 100% /mnt/pool-a/jails/plexmediaserver_1/proc /mnt/pool-a/jails/plexmediaserver_1/plex-media 11018447720 131402008 10887045712 1% /mnt/pool-a/jails/plexmediaserver_1/home/plex-media [root@freenas ~]#
Mark Waite
