[Dec 3 09:09] ata5.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ +0.000199] ata5.00: irq_stat 0x40000001
[ +0.000175] ata5.00: failed command: FLUSH CACHE EXT
[ +0.000167] ata5.00: cmd ea/00:00:00:00:00/00:00:00:00:00/a0 tag 13
res 53/04:00:b8:51:cf/00:00:fe:05:00/a0 Emask 0x1 (device error)
[ +0.000374] ata5.00: status: { DRDY SENSE ERR }
[ +0.000174] ata5.00: error: { ABRT }
[ +0.006599] ata5.00: n_sectors mismatch 27344764928 != 0
[ +0.000278] ata5.00: revalidation failed (errno=-19)
[ +0.000252] ata5: limiting SATA link speed to 3.0 Gbps
[ +0.000216] ata5.00: limiting speed to UDMA/100:PIO3
[ +0.000201] ata5: hard resetting link
[ +0.314326] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ +0.000454] ata5.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
[ +0.000379] ata5.00: revalidation failed (errno=-5)
[ +0.000252] ata5.00: disable device
[ +5.247906] ata5: hard resetting link
[ +0.314563] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ +0.000551] ata5.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
[ +5.060879] ata5: hard resetting link
[ +0.315026] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ +0.001494] ata5.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
[ +0.000914] ata5: limiting SATA link speed to 3.0 Gbps
[ +5.058598] ata5: hard resetting link
[ +0.314722] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ +0.001427] ata5.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
[ +5.063938] ata5: hard resetting link
[ +0.319179] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ +0.000671] sd 5:0:0:0: [sdl] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=22s
[ +0.000108] sd 5:0:0:0: rejecting I/O to offline device
[ +0.000538] sd 5:0:0:0: [sdl] tag#13 Sense Key : Illegal Request [current]
[ +0.000596] I/O error, dev sdl, sector 4412916832 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ +0.000612] sd 5:0:0:0: [sdl] tag#13 Add. Sense: Unaligned write command
[ +0.000650] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=2257265868800 siz>
[ +0.000654] sd 5:0:0:0: [sdl] tag#13 CDB: Synchronize Cache(10) 35 00 00 00 00 00 00 00 00 00
[ +0.001435] I/O error, dev sdl, sector 3710137552 op 0x0:(READ) flags 0x0 phys_seg 3 prio class 2
[ +0.000038] I/O error, dev sdl, sector 3188158016 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ +0.000014] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=1 offset=1630189355008 siz>
[ +0.000021] I/O error, dev sdl, sector 4301974816 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ +0.000009] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=2200463556608 siz>
[ +0.000016] I/O error, dev sdl, sector 25749836232 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ +0.000008] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=13181768601600 si>
[ +0.000014] I/O error, dev sdl, sector 4298143560 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ +0.000007] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=2198501953536 siz>
[ +0.000056] I/O error, dev sdl, sector 4301974824 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 2
[ +0.000002] I/O error, dev sdl, sector 4194960 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ +0.000009] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=1 offset=270336 size=8192 >
[ +0.000005] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=2200463560704 siz>
[ +0.000024] I/O error, dev sdl, sector 27344763536 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ +0.000008] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=1 offset=13998371381248 si>
[ +0.000011] I/O error, dev sdl, sector 4359288736 op 0x1:(WRITE) flags 0x0 phys_seg 2 prio class 2
[ +0.000010] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=2229808283648 siz>
[ +0.000001] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=1 offset=13998371643392 si>
[ +0.000028] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=2256677965824 siz>
[ +0.000017] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=2262439178240 siz>
[ +0.000019] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=2 offset=2264731918336 siz>
[ +0.000394] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=5 offset=0 size=0 flags=10>
[ +0.000422] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=1 offset=1897442877440 siz>
[ +0.000178] ata5: EH complete
[ +0.000403] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=1 offset=1897442893824 siz>
[ +0.010230] ata5.00: detaching (SCSI 5:0:0:0)
[ +0.004242] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=1 offset=1897442910208 siz>
[ +0.019176] md/raid1:md124: Disk failure on sdl1, disabling device.
md/raid1:md124: Operation continuing on 1 devices.
[ +0.036096] sd 5:0:0:0: [sdl] Synchronizing SCSI cache
[ +0.000633] sd 5:0:0:0: [sdl] Synchronize Cache(10) failed: Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ +0.000474] sd 5:0:0:0: [sdl] Stopping disk
[ +0.000499] sd 5:0:0:0: [sdl] Start/Stop Unit failed: Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ +0.510785] zio pool=TrueNAS vdev=/dev/disk/by-partuuid/56f3655d-2ed5-11ed-ab7a-3cecef8c44fa error=5 type=1 offset=270336 size=8192 >
[ +4.170870] md124: detected capacity change from 4188160 to 0
[ +0.000014] md: md124 stopped.
