VioletDragon
- Aug 6, 2017
I had a email yesterday from my Storage Server complaining about /dev/da5 [SAT], Failed SMART usage Attribute: 5 Reallocated_Sector_Ct. I did a smart test and it shows passed i decided to offline it and run it Seagate tools on this disk and all tests passed ive also did a full wipe on the disk and still have this /dev/da5 [SAT], Failed SMART usage Attribute: 5 Reallocated_Sector_Ct error, SMART results seems to be okay. Any ideas?
Thanks.
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate IronWolf
Device Model: ST3000VN007-2AH16M
Serial Number: ZD
LU WWN Device Id: 5 000c50 0c3117743
Firmware Version: SC60
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5980 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed May 13 06:45:21 2020 BST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 581) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 481) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 082 064 044 Pre-fail Always - 173945088
3 Spin_Up_Time 0x0003 094 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 14
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 079 061 045 Pre-fail Always - 71657407
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 3106 (96 230 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 14
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 1
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 076 066 040 Old_age Always - 24 (Min/Max 24/26)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 14
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 91
194 Temperature_Celsius 0x0022 024 040 000 Old_age Always - 24 (0 12 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 3098 (93 108 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 24484545283
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 38362697144
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 3104 -
# 2 Short offline Completed without error 00% 3079 -
# 3 Extended offline Completed without error 00% 2991 -
# 4 Short offline Completed without error 00% 2912 -
# 5 Short offline Completed without error 00% 2715 -
# 6 Extended offline Completed without error 00% 2626 -
# 7 Short offline Completed without error 00% 2547 -
# 8 Short offline Completed without error 00% 2379 -
# 9 Extended offline Completed without error 00% 2289 -
#10 Short offline Completed without error 00% 2211 -
#11 Short offline Completed without error 00% 1972 -
#12 Extended offline Completed without error 00% 1886 -
#13 Short offline Completed without error 00% 1808 -
#14 Short offline Completed without error 00% 1640 -
#15 Extended offline Completed without error 00% 1551 -
#16 Short offline Completed without error 00% 1473 -
#17 Short offline Completed without error 00% 1281 -
#18 Extended offline Interrupted (host reset) 20% 1190 -
#19 Short offline Completed without error 00% 1113 -
#20 Short offline Completed without error 00% 945 -
#21 Extended offline Completed without error 00% 855 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Thanks.
