Sadly, I'm about 400 miles away from the box right now for another 1-2 months. Best I can do is provide the output of
# dmidecode 2.12
SMBIOS 2.4 present.
38 structures occupying 1123 bytes.
Table at 0x000F0000.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: Phoenix Technologies, LTD
Version: 6.00 PG
Release Date: 03/24/2008
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 512 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supported
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: EVGA
Product Name: 132-CK-NF78
Version: 2
Serial Number: 1
UUID: EF91D15A-164B-0400-0000-000000000000
Wake-up Type: Power Switch
SKU Number:
Family:
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Manufacturer: EVGA
Version: 2
Serial Number: 1
Handle 0x0003, DMI type 3, 17 bytes
Chassis Information
Manufacturer: EVGA
Type: Desktop
Lock: Not Present
Version: 132-CK-NF78
Serial Number:
Asset Tag:
Boot-up State: Unknown
Power Supply State: Unknown
Thermal State: Unknown
Security Status: Unknown
OEM Information: 0x00000000
Handle 0x0004, DMI type 4, 35 bytes
Processor Information
Socket Designation: Socket 775
Type: Central Processor
Family: Other
Manufacturer: Intel
ID: 76 06 01 00 FF FB EB BF
Signature: Type 0, Family 6, Model 23, Stepping 6
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Core(TM)2 Duo CPU
Voltage: 1.7 V
External Clock: 360 MHz
Max Speed: 200 MHz
Current Speed: 3240 MHz
Status: Populated, Enabled
Upgrade: ZIF Socket
L1 Cache Handle: 0x000A
L2 Cache Handle: 0x000B
L3 Cache Handle: Not Provided
Serial Number:
Asset Tag:
Part Number:
Handle 0x0005, DMI type 5, 24 bytes
Memory Controller Information
Error Detecting Method: None
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 32 MB
Maximum Total Memory Size: 128 MB
Supported Speeds:
70 ns
60 ns
Supported Memory Types:
Standard
EDO
Memory Module Voltage: 5.0 V
Associated Memory Slots: 4
0x0006
0x0007
0x0008
0x0009
Enabled Error Correcting Capabilities: None
Handle 0x0006, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: A0
Bank Connections: 0 1
Current Speed: 10 ns
Type: Other
Installed Size: 2048 MB (Double-bank Connection)
Enabled Size: 2048 MB (Double-bank Connection)
Error Status: OK
Handle 0x0007, DMI type 6, 12 bytes
Socket Designation: A1
Bank Connections: 2 3
Type: Other
Error Status: OK
Handle 0x0008, DMI type 6, 12 bytes
Socket Designation: A2
Bank Connections: 4 5
Type: Other
Error Status: OK
Handle 0x0009, DMI type 6, 12 bytes
Socket Designation: A3
Bank Connections: 6 7
Type: Other
Error Status: OK
Handle 0x000A, DMI type 7, 19 bytes
Cache Information
Socket Designation: Internal Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 32 kB
Maximum Size: 32 kB
Supported SRAM Types:
Synchronous
Installed SRAM Type: Synchronous
Speed: Unknown
Error Correction Type: None
System Type: Instruction
Associativity: 8-way Set-associative
Handle 0x000B, DMI type 7, 19 bytes
Cache Information
Socket Designation: External Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 0 kB
Maximum Size: 0 kB
Synchronous
Speed: Unknown
System Type: Unified
Handle 0x000C, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: PRIMARY IDE
Internal Connector Type: On Board IDE
External Reference Designator: Not Specified
External Connector Type: None
Port Type: Other
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: FDD
Internal Connector Type: On Board Floppy
Port Type: 8251 FIFO Compatible
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: COM1
Internal Connector Type: 9 Pin Dual Inline (pin 10 cut)
External Connector Type: DB-9 male
Port Type: Serial Port 16450 Compatible
Handle 0x000F, DMI type 8, 9 bytes
Internal Reference Designator: Keyboard
Internal Connector Type: PS/2
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: PS/2 Mouse
Port Type: Mouse Port
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: Not Specified
Internal Connector Type: None
External Reference Designator: USB0
External Connector Type: Other
Port Type: USB
Handle 0x0012, DMI type 8, 9 bytes
External Reference Designator: USB1
Port Type: USB
Handle 0x0013, DMI type 8, 9 bytes
External Reference Designator: USB2
Port Type: USB
Handle 0x0014, DMI type 8, 9 bytes
External Reference Designator: USB3
Port Type: USB
Handle 0x0015, DMI type 8, 9 bytes
External Reference Designator: USB4
Port Type: USB
Handle 0x0016, DMI type 8, 9 bytes
External Reference Designator: USB5
Port Type: USB
Handle 0x0017, DMI type 9, 13 bytes
System Slot Information
Designation: PCI0
Type: 32-bit PCI
Current Usage: Available
Length: Long
Characteristics:
5.0 V is provided
PME signal is supported
Handle 0x0018, DMI type 9, 13 bytes
Designation: PCI1
Type: 32-bit PCI
Length: Long
Characteristics:
5.0 V is provided
Handle 0x0019, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 3
n|US|iso8859-1
n|US|iso8859-1
r|CA|iso8859-1
Currently Installed Language: n|US|iso8859-1
Handle 0x001A, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Maximum Capacity: 2 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x001B, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x001A
Total Width: 128 bits
Data Width: 128 bits
Form Factor: DIMM
Set: None
Locator: A0
Bank Locator: Bank0/1
Type: DRAM
Type Detail: None
Speed: 800 MHz
Manufacturer: None
Serial Number: None
Asset Tag: None
Part Number: None
Handle 0x001C, DMI type 17, 27 bytes
Memory Device
Form Factor: DIMM
Set: None
Locator: A1
Bank Locator: Bank2/3
Type: DRAM
Type Detail: None
Speed: 800 MHz
Manufacturer: None
Serial Number: None
Asset Tag: None
Part Number: None
Handle 0x001D, DMI type 17, 27 bytes
Memory Device
Form Factor: DIMM
Set: None
Locator: A2
Bank Locator: Bank4/5
Type: DRAM
Type Detail: None
Speed: 800 MHz
Manufacturer: None
Serial Number: None
Asset Tag: None
Part Number: None
Handle 0x001E, DMI type 17, 27 bytes
Memory Device
Form Factor: DIMM
Set: None
Locator: A3
Bank Locator: Bank6/7
Type: DRAM
Type Detail: None
Speed: 800 MHz
Manufacturer: None
Serial Number: None
Asset Tag: None
Part Number: None
Handle 0x001F, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x001FFFFFFFF
Range Size: 8 GB
Physical Array Handle: 0x001A
Partition Width: 1
Handle 0x0020, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x0007FFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x001B
Memory Array Mapped Address Handle: 0x001F
Partition Row Position: 1
Handle 0x0021, DMI type 20, 19 bytes
Starting Address: 0x00080000000
Ending Address: 0x000FFFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x001C
Handle 0x0022, DMI type 20, 19 bytes
Starting Address: 0x00100000000
Ending Address: 0x0017FFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x001D
Handle 0x0023, DMI type 20, 19 bytes
Starting Address: 0x00180000000
Range Size: 2 GB
Physical Device Handle: 0x001E
Handle 0x0024, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Handle 0x0025, DMI type 127, 4 bytes
End Of Table
In the past I have run smart long tests on the disks. No issues were reported. I just kicked off
on each of the disks in the pool within question. I'll have some new results in a few hours (estimates 455 minutes for each).
It could very well be the lack of RAM issue. Is there any way to determine that? Would adding more LOG cache on an SSD help the issue?
I will play around with tuneables for ZFS tonight and see what I can do. Do you know if there is a way to push ARC into swap? I could then move swap to an SSD to get better performance (hopefully) out of swap and therefore better out of ARC (theoretically based on my knowledge).
zpool status shows 36 read errors on one disk and 4 in the other. As I mentioned, the disks have seen their fair share of use and are approaching end of life within ~6 months.
I don't have an empty pool to test with. It'll be 1-2 months before I have physical access to the box again and I'm able to install some disks to test this theory. But no, this didn't happen on the SSD pool when it was originally installed, but I do acknowledge your point #1 above about the SSD's flushing faster.
I will perform some tests on local writes from the SSD pool to the HDD pool. I'm going to try
to see if any of those commands yield different results.
1. Determine if it is a disk or disks that is causing the problem, and..
2. Which disk in the pool is causing the problem, if it is only one disk.
