Hi All,
Had a search through the forums but couldn't find anything recent that addresses the issue.
TrueNAS-13.0-U3.1
I had a simple mirrored data vdev with two drives.
One started throwing SMART errors, so I purchase a new disk.
The 'replace' option only showed existing disks, but I needed to physically swap them so I wrongly assumed the best option would be to 'detach' the failed disk - leaving a single disk in the vdev.
I then physically swapped the drives but cannot find an option to rebuild the mirror.
There is an "add vdev" option, but doesn't show the existing disk and if I try to add the new disk it says "stripe".
Any way to resolve this without blowing away the whole vdev, building a new vdev and restoring from backup?
Thanks in advance!
TrueNAS-13.0-U3.1
Thanks in advance!
