cowboydude
- Apr 18, 2022
Hi all,
I'm new here. I've read through some of the posts and a PDF explaining how TrueNAS works, but still have questions. I apologize in advance if I should know some of this already!
I am running a system used for streaming various media files across my network.
The current setup is 4 networks shares (SMB). Each share is on its own HDD. The user must go to the right share to find the video they need. This isn't the most efficient way to do things... and also there is no redundancy in place.
I have four 8TB WD Red drives and two 4TB WD Red drives.
I'm planning on the following and hoping you could validate this configuration or point out any flaws with performance or any other issues you may see.
System:
Server - Running VMware 7.
HBA - IBM M1015 in IT mode. Set to passthru from VMware to the TrueNAS VM.
TrueNAS VM - 4 CPUs, 8GB RAM (may increase to 16GB).
VDEV1 - 4x 8TB drives. RAIDZ1. Should two drives fail at the same time, it is time consuming to restore from a backup... but doable.
VDEV2 - 2x 4TB drives. Mirror. Data is also backed up offsite.
Would you setup 2 pools or 1 pool? Is there a benefit to setting up multiple pools vs a single pool with two shared folders?
Looking for some guidance.
Thank you!
System:
Thank you!
