So I know a lot of the UI stuff for Containers is breaking right now as it marches towards the next release, but while trying to launch an image not in the catalog using the Launch Docker Image button, I get the following after filling everything out. Using one Host path volume one Volume
Error: [EFAULT] Failed to install catalog item: b'Error: unable to build kubernetes objects from release manifest: error validating "": error validating data: ValidationError(Deployment.spec.template.spec.containers[0].volumeMounts[1]): missing required field "mountPath" in io.k8s.api.core.v1.VolumeMount\n'
I'll get an issue open for it in a bit after I do some more testing to figure out if its host path volume or Volume unless someone beats me to it
