all,
I have 2 dell r730xd (one 24 bay one 12 bay) with H730 mini cards set at "HBA Mode". i have been suspect about something since the performance does not seem any better than my R510 with H200 (flashed to IT). i ran dmesg | grep transfers and got this below
root@freenas130[~]# dmesg | grep transfers
ses0: 150.000MB/s transfers
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
da0: 150.000MB/s transfers
da5: 150.000MB/s transfers
da3: 150.000MB/s transfers
da1: 150.000MB/s transfers
da7: 150.000MB/s transfers
da10: 150.000MB/s transfers
da14: 150.000MB/s transfers
da9: 150.000MB/s transfers
da2: 150.000MB/s transfersda15: <HGST HUC156060CSS200 A703> Fixed Direct Access SPC-4 SCSI device
da15: 150.000MB/s transfers
da12: 150.000MB/s transfers
da6: 150.000MB/s transfers
da11: 150.000MB/s transfers
da4: 150.000MB/s transfers
da8: 150.000MB/s transfers
da13: 150.000MB/s transfers
root@freenas130[~]#
when i run the same command on my R510 machines the transfers are 600.000MB/s
i am trying to find out if anyone else has seen the same thing? and is there a fix ?
i had thought about going to the actual Dell HBA330 or flashing one of my H330 to the HBA330 firmware as seen here
							 forums.servethehome.com
any input appreciated
root@freenas130[~]#
Flash/Crossflash DELL H330 RAID Card to HBA330/12Gbps HBA IT Firmware
Success! You can now flash the Dell PERC H330 (All Models) to IT Mode (HBA330).  Big Thanks to BLinux for asking if it could be done! (Inspiration!)  So I initially had a super long write-up, but that's way too long, you just need the compact steps. I linked the write up at the end of the...
