OK So if I start from scratch, is there a better way for my ESX hosts to see the data than using an extent? Ideally, I would like to be able to actually view (browse) the VM files, rather than browsing to one large extent file...
When I was doing this before, if I opened a file explorer to the Freenas, all I would see is the jails folder, and my extent, but I could not actually see the data.
***UPDATE***
Did some more research and tried setting up NFS Share for my ESX hosts. This seems to work fine. I am concerned about the performance difference. I was hoping to be able to use crashplan to backup some of the VM files, but crashplan only sees the extent as one file, so I would be backing up my entire 7TB extent to the cloud.
