Delete NT4 Configuration
eroji
Is there a way to delete config already saved in the NT4 section of the Directory Service? I am currently using Active Directory but had entered in config in NT4 tab at one point.
D
dlavigne
Guest
Does unchecking the Enable box do it? If not, what errors do you get when you activate the Active Directory service?
eroji
It's not enabled but the OCD part of me wants to clear the entries in the fields, if it's possible.
You could manually clear the entries in the database. But to be honest, I wouldn't go that far as you risk breaking things as some fields *have* to have something there and what-not.
I'd leave well enough alone, or go with a new config file if you just *gotta* do something.
