Delete Mirror Partition unintentionally
waverap
I made the mistake of giving to delete the partition that was not and I deleted to delete data. I have not touched anything else is a mirror 2 1TB drives . I wonder if I can recover information in some way and if I could get lift it again. I have not formatted nor have I touched anything more . I 'm in Abla Ontrack to recover the disks but I charged 1000 euros minimum and not think it's so difficult because the data should remain . Thank you help me and I am a little desperate and I had 500GB on photos.
You'll have to be a lot clearer.
Please explain:
  • Your hardware setup
  • FreeNAS version
  • What this mysterious "partition" is
  • Your pool layout
...and if you are not a native English speaker and are having difficulty translating your thoughts to English, note that there are subforums here for several other languages. You might find it easier to communicate in your native language, though at the expense of somewhat-diminished exposure of your question. Those forums are listed here: https://forums.freenas.org/index.php#international.28
waverap
My Feenas is 9.3
My hardware AMD 1100T, 16Gb Ram, 4 HDD 3TB WDred (RaidZ2), 2 HDD 1TB seagate (Mirror), 1SSD cache for Raidz2 WDred.
My problem is: I deleted the mirror partition with mark delete data, and i need recovery files on this partition.
i dont formated partition and not rewrite on this. ontrack easy recovery tell me recovery cost over 2000€ to 4000€
can i recover with program or alternative, i need solution :(.
i dont speak much english but in spanish no much help.
thanks for your reply.
I'll have to warn you that I speak no Spanish at all, but hopefully I can at least help confirm what has happened. It sounds like you had a pool, or what FreeNAS calls a "volume" (or "volumen" in Spanish, it appears) on those two drives. You detached the pool ("Desmontar volumen"), and when you did, you checked the box for "Marcar disco como nuevo (borrar información):". Is that correct?
If so, I'm afraid I don't know of any way to recover the data on those drives--hopefully someone else can chime in with more encouraging information.
waverap
exact, i deleted the data on volumen mirror and i lost the pool. thanks for your help
i find http://www.ufsexplorer.com/ program recovery ZFS i dont know works or not.
http://www.ufsexplorer.com/download_stdrr.php
http://www.cgsecurity.org/wiki/TestDisk_Step_By_Step
wen i use i speak results of try recovery data.
thanks for your help.
Bidule0hm
Server Electronics Sorcerer
The first thing I'd do is to image the drives with the dd command (be careful when you use it, it is a dangerous command) so whatever thing you do to the drives next you still have a backup of the actual state of the drives ;)
