Degraded Pool
LIGISTX
Hey guys, I got an email last night about a degraded pool, but I am not 100% sure what is actually wrong here.
When I run zpool status I get this. Should I assume all has been fixed clear the issue (I think that is zpool clear?). I did have a drive not show up initially when I rebooted after some hardware changes, but I am not sure if that caused this issue.
Thanks for the help!
          raidz2-0                                      DEGRADED     0     0     0
            gptid/ab0351e8-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/abbfceac-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/ac8d872a-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/ad4a2436-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/ae0d7e64-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/aeca106f-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/af89686d-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/b04ad4fc-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/b10b6452-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0     0
            gptid/b1d949c1-44ea-11e8-8cad-e0071bffdaee  DEGRADED     0     0    81  too many errors
errors: No known data errors
tfran1990
There might be a problem with that last disc (gptid/b1d949c1-44ea-11e8-8cad-e0071bffdaee)
it could be cable/connector related.
how are you connecting the disc to your freenas?
LIGISTX
Freenas is virtualized under ESXi with my HBA passed through to freenas, so it does see it “bare metal”. From the HBA I run a SAS expander and then SAS to quad SATA plugs to my drives. It hasn’t been an issue in the past, but as luck has it, seemingly every time I physically move the box, I get an issue of some sort, usually a plug that wiggled out or something. I have checked the cables and they seem fine though.
I am not extremely well versed in ZFS, so while I think it isn’t an issue, I very easily could be wrong, and I wouldn’t know what to check fo confirm one way or another.
tfran1990
reseat the cable and do a smartctl -t long on that last device and see if maybe that 81 changes. you could also switch the disc that has 81 errors to a different cable or even a different port on the expander to see if the problem follows.
Jessep
Are you running scheduled SMART tests?
LIGISTX
LIGISTX
So I have a scheduled Long smart test tonight actually, and will get an email in a few days of the pool status and smart report. I suppose I should just wait until that is all completed before I make any assumptions?
LIGISTX
Actually, I found this old report I got immediately after I had the issue when I physically moved the box and I had a degraded state issue at bootup. It only saw 9 of my 10 drives, and once I got all 10 showing up again, I got this:
          raidz2-0                                      ONLINE       0     0     0
            gptid/b1d949c1-44ea-11e8-8cad-e0071bffdaee  ONLINE       0     0    13
Does this mean the drive is in fact getting worse and thus needs to be replaced? Or could it simply be a bad cable and a reboot/cable swap may fix my problem?
LIGISTX
Any ideas with this new info ^?
Thanks!
You're getting CRC errors, which on their own point to cables rather than disks. If you clear the errors and do a scrub, do they come back?
LIGISTX
Clear the errors via zpool clear? Try a different cable, scrub, and see what happens?
LIGISTX
Yes, that's what I intended.
Ok, after a scrub and smart Long, same numbers. So I did zpool clear, figured out what disc it was mad about, reseated the SATA which so far seems to have fixed it, and am running a scrub now. Will run a Long after that as well and see what info I get.
Thanks!
Although a cabling change would not be expected to have any impact on the SMART findings as those tests are run from the onboard controller on the disk itself... no cables in that pathway.
LIGISTX
Ah, that’s a good point I hadn’t considered. Thanks for pointing that out!
