Degraded and unable to replace
hummer5
Hi all,
I have a freenas with 9.1.1 installed. I have tried to put the drive in offline mode which didn't work as it was giving me read errors. I then removed it manually and then now it is showing me a number in the volume status which is only giving me option to replace and with all the efforts i am unable to do so. Can someone please help me. I have tried to follow the manual but couldn't do much.
Name
Read
Write
Checksum
RAIDZ 0 0 0 DEGRADED
raidz2-0 0 0 0 DEGRADED
da5p2 0 0 0 ONLINE
9435462731378152769 0 0 0 UNAVAIL
da3p2 0 0 0 ONLINE
da2p2 0 0 0 ONLINE
da1p2 0 0 0 ONLINE
da0p2 0 0 0 ONLINE
Well, for starters, it looks like you didn't create the pool from the GUI. If you had instead of being da0p2 it would have a gptid. So you have bigger problems to deal with and I have no recommendations because I can't assume you had used the GUI. My guess is that you created it from the command line.
hummer5
I finally was able to fix it via command line.
Thank you so much. Appreciate quick reply: I know I have to learn a lot and will keep working on it.
Thanks again
