I was maitaining my system and unintentionally unplug 1 power cord on 1 of my disks.
When the system boot the pool was degraded, I notice that the cable wasn't plugued and turned off the system and then proced to plug the cable.
Now the disk have power and is being recognised on the freebsd but is not recognised on freenas.
Tried to make the drive online
Disk being recognised
How can I fix this?
Thank you!
root@freenas[~]# zpool status -v
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:01:30 with 0 errors on Thu Feb 13 03:46:30 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
errors: No known data errors
pool: vault
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 0 days 02:33:19 with 0 errors on Sat Feb 1 02:33:19 2020
vault DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
gptid/6f88fe5d-28c7-11e9-ae80-e03f49b305e4.eli ONLINE 0 0 0
468245421987963022 UNAVAIL 0 0 0 was /dev/gptid/7002d707-28c7-11e9-ae80-e03f49b305e4.eli
root@freenas[~]# smartctl -a /dev/ada2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red Pro
Device Model: WDC WD4003FFBX-68MU3N0
Serial Number: V6GLU62R
LU WWN Device Id: 5 000cca 097c88d43
Firmware Version: 83.00A83
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Feb 15 18:02:28 2020 WET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 87) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 452) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0004 132 132 054 Old_age Offline - 96
3 Spin_Up_Time 0x0007 146 146 024 Pre-fail Always - 309 (Average 272)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 144
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0
8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 6659
10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 144
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 411
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 411
194 Temperature_Celsius 0x0002 206 206 000 Old_age Always - 29 (Min/Max 14/41)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 6650 -
# 2 Short offline Completed without error 00% 6570 -
# 3 Short offline Completed without error 00% 6402 -
# 4 Extended offline Completed without error 00% 6267 -
# 5 Short offline Completed without error 00% 6234 -
# 6 Short offline Completed without error 00% 6069 -
# 7 Extended offline Completed without error 00% 5909 -
# 8 Short offline Completed without error 00% 5901 -
# 9 Short offline Completed without error 00% 5740 -
#10 Extended offline Completed without error 00% 5584 -
#11 Short offline Completed without error 00% 5456 -
#12 Short offline Completed without error 00% 5290 -
#13 Extended offline Completed without error 00% 5226 -
#14 Short offline Completed without error 00% 5123 -
#15 Short offline Completed without error 00% 4955 -
#16 Extended offline Completed without error 00% 4867 -
#17 Short offline Completed without error 00% 4793 -
#18 Short offline Completed without error 00% 4739 -
#19 Extended offline Completed without error 00% 4644 -
#20 Short offline Completed without error 00% 4587 -
#21 Short offline Completed without error 00% 4422 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@freenas[~]# zpool online 468245421987963022
missing device name
usage:
online [-e] <pool> <device> ...
root@freenas[~]# zpool online vault 468245421987963022
warning: device '468245421987963022' onlined, but remains in faulted state
use 'zpool replace' to replace devices that are no longer present
</code>
<code>
root@freenas[~]# zpool replace vault ada2
cannot replace ada2 with ada2: no such device in pool
root@freenas[~]# zpool replace vault gptid/7002d707-28c7-11e9-ae80-e03f49b305e4
cannot replace gptid/7002d707-28c7-11e9-ae80-e03f49b305e4 with gptid/7002d707-28c7-11e9-ae80-e03f49b305e4: no such device in pool
root@freenas[~]#
root@freenas[~]# zpool replace vault 468245421987963022
cannot open '468245421987963022': no such GEOM provider
must be a full path or shorthand device name
root@freenas[~]# gpart show ada2
=> 40 7814037088 ada2 GPT (3.6T)
40 88 - free - (44K)
128 4194304 1 freebsd-swap (2.0G)
4194432 7809842696 2 freebsd-zfs (3.6T)
Geom name: ada1
Providers:
1. Name: ada1
Mediasize: 4000787030016 (3.6T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r2w2e5
descr: WDC WD4003FFBX-68MU3N0
lunid: 5000cca097cb677f
ident: V6GU2RDR
rotationrate: 7200
fwsectors: 63
fwheads: 16
Geom name: ada2
Providers:
1. Name: ada2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e2
lunid: 5000cca097c88d43
ident: V6GLU62R
rotationrate: 7200
fwsectors: 63
fwheads: 16
How can I fix this?
Thank you!
