From what dscape mentions in Post #4, it seems like I'm doing something similar.
I had an esxi box with local storage. I run a backup script locally on that box that mounts an nfs share (freenas), snapshots each vm in turn, and copies the (now static) vmdk / vmx to the nfs share. It then deletes the vm snapshot returning things to normal.
These are by definition full backups everyday. But with dedupe, I save all the duplicated space, so each 'full' backup only really uses disk space from what's changed in the .vmdk image.
I tried lz4 vs gzip9, and settled on gzip9. lz4 was only slightly (15% or so) faster, and was network bound. Enabling gzip9 actually is cpu bound, but just barely, as it's only a bit slower than lz4.
As to whether the values are meaningful for not, I have no idea. That's the output from "zdb -D" though. Here's the raw output if it matters:
root@nas2 ~ # zpool list
NAME      SIZE  ALLOC  FREE    CAP  DEDUP  HEALTH  ALTROOT
nas2pool  32.5T  9.36T  23.1T    28%  18.49x  ONLINE  /mnt
root@nas2 ~ # zdb -Dv nas2pool
DDT-sha256-zap-duplicate: 579601 entries, size 1309 on disk, 211 in core
DDT-sha256-zap-unique: 206626 entries, size 1658 on disk, 267 in core
DDT histogram (aggregated over all DDTs):
bucket              allocated                      referenced
______  ______________________________  ______________________________
refcnt  blocks  LSIZE  PSIZE  DSIZE  blocks  LSIZE  PSIZE  DSIZE
    1    202K  25.2G  3.76G  4.60G    202K  25.2G  3.76G  4.60G
    2    56.0K  7.00G  1.76G  1.99G    130K  16.2G  4.06G  4.59G
    4    39.7K  4.97G  1.58G  1.70G    202K  25.2G  8.10G  8.75G
    8    28.3K  3.54G  1017M  1.09G    312K  39.1G  10.5G  11.6G
    16    438K  54.8G  34.9G  35.8G    9.60M  1.20T    781G    799G
    32    3.65K    467M    198M    210M    167K  20.8G  8.82G  9.38G
    64      256  31.9M  12.2M  13.1M    18.2K  2.27G    864M    930M
  128        6    768K    24K  48.0K      908    114M  3.55M  7.09M
  256        3    384K    12K  24.0K    1.13K    145M  4.52M  9.04M
  512        1    128K      4K  7.99K      736    92M  2.88M  5.74M
    4K        1    128K      4K  7.99K    7.32K    938M  29.3M  58.5M
  16K        1    128K      4K  7.99K    16.9K  2.11G  67.4M    135M
Total    768K  96.0G  43.2G  45.4G    10.6M  1.33T    817G    839G
dedup = 18.50, compress = 1.67, copies = 1.03, dedup * compress / copies = 30.00
If I'm calculating things right, the DDT's should be using (768,000 * 320 bytes) of ARC. That only about 234 MB. I would have had the pool space to do this without dedupe, but I wanted to see how it worked. It's a backup nas, so I'm not terribly worried about having dedupe ram issues. I totally accept that I might lose the pool due to insufficient ram. This is kind of my 'experiment' box. It's only got 12 gigs of ram, which for the pool size it has, is already a bit low. Plus the little bit of dedupe I'm doing.  Also note that dedupe is only enabled on the dataset I use for vm backup.  The rest of the pool would dedupe extremely poorly.
Anyway, I'm not trying to derail the OP's thread, I just wanted to point out it's quite possible to have dedupe ratio's in excess of 2.0.
