- Mar 5, 2013
Not familiar with this, so I can't comment.On the server, I use the OpenSpeedTest plugin.
This test isn't really accurate cause it only measures the speed of your laptop connection with the internet, not to your server, which is what matters.On the laptop, I use the speedtest by Ookla.
If this is through SMB, and with files you've used in the past, it's possible that most of the transfer has already been cached and you're getting much faster speeds.For the video transfer from the server to my desktop, I look at the file transfer speed.
Also worth noting, you could get different speeds on iperf depending on which one is the server and which one is the client. See what happens when you reverse the two commands.
