DDNS: tons of "checkip.dyndns.com seems unstable" in my logs
Sawtaytoes
Getting these log messages about `checkip.dyndns.com`:
Jan  4 08:12:22 storeman inadyn[18599]: Please note, checkip.dyndns.com seems unstable, consider overriding it in your configuration with 'checkip-server = default'
Jan  4 23:03:23 storeman inadyn[18599]: Communication with checkip server checkip.dyndns.com failed, run again with 'inadyn -l debug' if problem persists
Jan  4 23:03:23 storeman inadyn[18599]: Retrying with built-in 'default', api.ipify.org ...
Jan  4 23:03:27 storeman inadyn[18599]: Please note, checkip.dyndns.com seems unstable, consider overriding it in your configuration with 'checkip-server = default'
Jan  5 02:28:42 storeman inadyn[18599]: Communication with checkip server checkip.dyndns.com failed, run again with 'inadyn -l debug' if problem persists
Jan  5 02:28:42 storeman inadyn[18599]: Retrying with built-in 'default', api.ipify.org ...
Jan  5 02:28:43 storeman inadyn[18599]: Please note, checkip.dyndns.com seems unstable, consider overriding it in your configuration with 'checkip-server = default'
My config:
My system:
I would like to remove these messasages from my logs because too much clutter makes it impossible to find real issues.
odoyle
Same here, any solution? I'm using myip.dnsomatic.com so it must not be related to the address?
