darkknight4714
- Jan 27, 2019
Hello everyone. This is my first post and I hope to get to know everyone a little better. I do hope that my forum behavior is acceptable as I don't often post in forums. :)
I have been a long time user of FreeNAS, since about 2013. I have loved using it and for the most part it has always, well, worked. Never had any problem with it that was not my own doing (Usually configs). But being a lurker, I have been able to solve most if not all of my issues with the plethera of information that is posted on these forums. That is until this morning...
Let me lay out the story and I will post all the information that I have. Let me know if I need to gather more information and I will be happy to get it.
So I logged onto my workstation and found that my SMB shares was missing folders, not disconnected, just missing a ton of folders. Thats odd, so I log into the GUI to find that the directory is basically empty other than a few files my wife uploaded earlier. So I have seen issues in the past that are easily resolved with a simple reboot. OK, power cycle the system and it comes up with a error while booting. "error 32 LBA something...". Okay, so I get a bootable usb drive, just to check if it the port, the usb drive or something on the usb drive. Well it boots. So i do some searching and it appears that I may have a toast USB drive. Fine, I have a backup config from earlier in the week. Easee-peezee. Except that someone wiped my backup configs. Darn! So here is where I fall back on why I love FreeNAS and zfs so much because I can just import the pool again and sure I'll have to fix all my configs, but the data will be there.
So I install a fresh copy of 11.2-RELEASE-U1 from the website. No biggie and things are going along quickly. Now its time to import the pools. I import pool "Dump" which is exactly that and it appears it has some bad sectors, no biggie, it was a, well, dumping ground and I dont take backups for that pool. But when I import the pool, all the datasets are missing. Thinking this might have something to do with the bad sectors, I move onto my second pool "MainStorage". I have never in the 3-4 migrations that I have done with this pool ever had a problem with it. I do the same thing and import the pool and same issue. Datasets are missing. About 4.2TB worth of it missing.
Now I dont think the datasets are missing, i just dont know how to get them to show up exactly. I have scoured the forums to see if there is anything and everyone that I have seen either has SOMETHING no their pool or nothing at all. And this with nothing at all appear to end up restoring or never respond to the thread again.
So, that leads me here. I will post all the information that I have gather based on information requests from others in past threads.
The pool that I care the most about is the MainStorage pool so you will only see Dump show up in list that are part of the global lists. What I am basically hoping for is to not do a full recovery on this pool. I can if needed, but I'd rather not if this is something rather simple.
Thanks Again!
Thanks Again!
Platform Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz Memory 8103MB 3x Toshiba 3TB RAIDZ1 1x Seagate 1TB Single Drive Pool [root@freenas /mnt/Dump]# zfs list NAME USED AVAIL REFER MOUNTPOINT Dump 205M 899G 980K /mnt/Dump Dump/.system 157M 899G 25K legacy Dump/.system/configs-1c36823397d74dbc9e7d4fbefe8b455e 1.02M 899G 1.02M legacy Dump/.system/configs-85575f3640124e06b9ead9eeda4080b1 23K 899G 23K legacy Dump/.system/cores 23K 899G 23K legacy Dump/.system/rrd-1c36823397d74dbc9e7d4fbefe8b455e 81.8M 899G 81.8M legacy Dump/.system/rrd-85575f3640124e06b9ead9eeda4080b1 68.7M 899G 68.7M legacy Dump/.system/samba4 4.83M 899G 4.83M legacy Dump/.system/syslog-1c36823397d74dbc9e7d4fbefe8b455e 177K 899G 177K legacy Dump/.system/syslog-85575f3640124e06b9ead9eeda4080b1 644K 899G 644K legacy Dump/.system/webui 23K 899G 23K legacy Dump/Jail 20K 899G 20K /mnt/Dump/Jail Dump/Repo 108K 899G 108K /mnt/Dump/Repo MainStorage 453M 5.24T 408M /mnt/MainStorage freenas-boot 762M 2.63G 64K none freenas-boot/ROOT 762M 2.63G 29K none freenas-boot/ROOT/Initial-Install 1K 2.63G 760M legacy freenas-boot/ROOT/default 762M 2.63G 760M legacy [root@freenas /mnt/Dump]# zpool list NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT Dump 928G 215M 928G - - 22% 0% 1.00x ONLINE /mnt MainStorage 8.12T 680M 8.12T - - - 0% 1.00x ONLINE /mnt freenas-boot 3.50G 763M 2.76G - - - 21% 1.00x ONLINE - [root@freenas /mnt/Dump]# zpool status pool: Dump state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0 days 02:38:45 with 11 errors on Sun Jan 20 02:38:46 2019 config: NAME STATE READ WRITE CKSUM Dump ONLINE 0 0 0 gptid/b630aade-d642-11e2-baee-0018f3a296ea ONLINE 0 0 0 errors: 3 data errors, use '-v' for a list pool: MainStorage state: ONLINE status: The pool is formatted using a legacy on-disk format. The pool can still be used, but some features are unavailable. action: Upgrade the pool using 'zpool upgrade'. Once this is done, the pool will no longer be accessible on software that does not support feature flags. scan: scrub repaired 0 in 0 days 03:05:27 with 0 errors on Sun Jan 13 03:05:28 2019 config: NAME STATE READ WRITE CKSUM MainStorage ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/e17dd9d2-d142-11e5-afbe-0018f3a296ea ONLINE 0 0 0 gptid/d570b63d-cf32-11e2-bbdb-0018f3a296ea ONLINE 0 0 0 gptid/d6269f12-cf32-11e2-bbdb-0018f3a296ea ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: none requested config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors [root@freenas /mnt/Dump]# zpool get all MainStorage NAME PROPERTY VALUE SOURCE MainStorage size 8.12T - MainStorage capacity 0% - MainStorage altroot /mnt local MainStorage health ONLINE - MainStorage guid 4767613106516338597 local MainStorage version 28 local MainStorage bootfs - default MainStorage delegation on default MainStorage autoreplace off default MainStorage cachefile /data/zfs/zpool.cache local MainStorage failmode wait default MainStorage listsnapshots off default MainStorage autoexpand on local MainStorage dedupditto 0 default MainStorage dedupratio 1.00x - MainStorage free 8.12T - MainStorage allocated 680M - MainStorage readonly off - MainStorage comment - default MainStorage expandsize - - MainStorage freeing 0 local MainStorage fragmentation - - MainStorage leaked 0 local MainStorage bootsize - default MainStorage checkpoint - - MainStorage feature@async_destroy disabled local MainStorage feature@empty_bpobj disabled local MainStorage feature@lz4_compress disabled local MainStorage feature@multi_vdev_crash_dump disabled local MainStorage feature@spacemap_histogram disabled local MainStorage feature@enabled_txg disabled local MainStorage feature@hole_birth disabled local MainStorage feature@extensible_dataset disabled local MainStorage feature@embedded_data disabled local MainStorage feature@bookmarks disabled local MainStorage feature@filesystem_limits disabled local MainStorage feature@large_blocks disabled local MainStorage feature@sha512 disabled local MainStorage feature@skein disabled local MainStorage feature@device_removal disabled local MainStorage feature@obsolete_counts disabled local MainStorage feature@zpool_checkpoint disabled local zpool history -il MainStorage ... 2019-01-13.03:05:28 [txg:32597075] scan done errors=0 [on freenas.local] 2019-01-27.03:10:10 [txg:32850744] open pool version 28; software version 5000/5; uts freenas.local 11.2-STABLE 1102500 amd64 [on fr eenas.local] 2019-01-27.03:10:11 [txg:32850746] import pool version 28; software version 5000/5; uts freenas.local 11.2-STABLE 1102500 amd64 [on freenas.local] 2019-01-27.03:10:11 zpool import -f -R /mnt 4767613106516338597 [user 0 (root) on freenas.local] 2019-01-27.03:10:11 zpool set cachefile=/data/zfs/zpool.cache MainStorage [user 0 (root) on freenas.local] 2019-01-27.03:10:12 [txg:32850749] inherit MainStorage (21) mountpoint=/ [on freenas.local] 2019-01-27.03:10:12 zfs inherit -r mountpoint MainStorage [user 0 (root) on freenas.local] 2019-01-27.03:10:12 [txg:32850750] set MainStorage (21) aclmode=3 [on freenas.local] 2019-01-27.03:10:12 zfs set aclmode=passthrough MainStorage [user 0 (root) on freenas.local] 2019-01-27.03:10:12 [txg:32850751] set MainStorage (21) aclinherit=3 [on freenas.local] 2019-01-27.03:10:17 zfs set aclinherit=passthrough MainStorage [user 0 (root) on freenas.local]
