SOLVED Data Corruption
Tom Blyth
I'm getting the following error, and I don't know how to fix it, please help!
How can I identify and remove the problem files?
WARNING: The volume ZFSVol1 (ZFS) status is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.Restore the file in question if possible. Otherwise restore the entire pool from backup.
pool: ZFSVol1
state: ONLINE
action: Restore the file in question if possible. Otherwise restore the
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub in progress since Thu Feb 13 13:37:38 2014
4.08T scanned out of 4.91T at 199M/s, 1h13m to go
44.5K repaired, 83.08% done
NAME STATE READ WRITE CKSUM
ZFSVol1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/24142f54-7160-11e1-8e92-50e5492532c5 ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/2486bd77-7160-11e1-8e92-50e5492532c5 ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/24f21ede-7160-11e1-8e92-50e5492532c5 ONLINE 0 0 0 block size: 512B configured, 4096B native
gptid/aca934bd-48a8-11e2-a24f-50e5492532c5 ONLINE 0 0 1 block size: 512B configured, 4096B native (repa
iring)
gptid/e37fdaf0-2dc4-11e3-89b8-50e5492532c5 ONLINE 0 0 0
gptid/ece4ba46-4edb-11e3-be81-50e5492532c5 ONLINE 0 0 0
<0x67>:<0x1560e>
<0x67>:<0x802b>
Thanks for any assistance :)
I don't know, but repost the zpool status in CODE tag or pastebin. The lack of formatting means your output is useless.
ECCfrenaslover
OP, what version of FreeNAS are you running?
