Dashboard widgets does not working
Yarik
Hello dear FreeNas Community
I have an issue with some WebUI dashboard widgets:
Memory Usage, CPU Usage, CPU Temperatures, Load Average - shows nothing
Network Info - always with a loading bar on top
I noticed it since 11.1 or even earlier.
I am running FreeNas under Proxmox VM, so it can be the cause, but may not be.
After short examination I found some JS errors in browser console log (something about rrdtool), so it should help
I realize that there is no full access to some hardware data (i.e. cpu/hdd temp and so on) in my case (VM & passthrough), but I think that some messages should be shown instead of empty widgets and console errors. Anyway I just want to know if this behavior is normal in my case. And it will be great if the information I provide will help to fix bug. Thanks.
Console JS error
22:42:54.504 ERROR TypeError: "t[0] is undefined"       main.9d0e0bcdf89b5356804c.bundle.js:1:1947329
   mergeMessages http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    startBroadcast http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    updateSources http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    __tryOrUnsub http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    next http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    _next http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    emit http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    callWebsocket http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    onmessage http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    x http://192.168.1.201/ui/polyfills.4e42ab25a6112b333361.bundle.js:1
    i http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    invokeTask http://192.168.1.201/ui/polyfills.4e42ab25a6112b333361.bundle.js:1
    onInvokeTask http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    runTask http://192.168.1.201/ui/polyfills.4e42ab25a6112b333361.bundle.js:1
    m http://192.168.1.201/ui/polyfills.4e42ab25a6112b333361.bundle.js:1
    b http://192.168.1.201/ui/polyfills.4e42ab25a6112b333361.bundle.js:1
    _t http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    handleError http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    onHandleError http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    invoke http://192.168.1.201/ui/polyfills.4e42ab25a6112b333361.bundle.js:1
    run http://192.168.1.201/ui/polyfills.4e42ab25a6112b333361.bundle.js:1
    runOutsideAngular http://192.168.1.201/ui/main.9d0e0bcdf89b5356804c.bundle.js:1
    handleError http://192.168.1.201/ui/polyfills.4e42ab25a6112b333361.bundle.js:1
Console JSON error (expanded):
  "error": 14,
  "type": null,
  "reason": "[EFAULT] rrdtool failed: ERROR: realpath(/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd): No such file or directory\n",
  "trace": {
    "class": "CallError",
    "frames": [
        "filename": "/usr/local/lib/python3.6/site-packages/middlewared/main.py",
        "lineno": 194,
        "method": "call_method",
        "line": "            self.send_error(message, e.errno, str(e), sys.exc_info(), extra=e.extra)\n",
        "argspec": [
          "self",
          "message"
        "locals": {
          "e": "CallError('rrdtool failed: ERROR: realpath(/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd): No such file or directory\\n',)",
          "message": "{'id': '383344b2-4b88-e908-f994-74115e818562', 'msg': 'method', 'method': 'stats.get_data', 'params': [[{'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}]]}",
          "self": "<middlewared.main.Application object at 0x81c1b99e8>"
        "lineno": 1098,
        "line": "        return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)\n",
        "argspec": [
          "self",
          "app",
          "message"
        "locals": {
          "methodobj": "<bound method accepts.<locals>.wrap.<locals>.nf of <stats.StatsService object at 0x819fedb70>>",
          "serviceobj": "<stats.StatsService object at 0x819fedb70>",
          "params": "[[{'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}]]",
          "app": "<middlewared.main.Application object at 0x81c1b99e8>",
          "self": "<middlewared.main.Middleware object at 0x80afdfbe0>"
        "lineno": 1046,
        "method": "_call",
        "line": "                return await methodobj(*args)\n",
        "argspec": [
          "self",
          "name",
          "serviceobj",
          "methodobj",
          "params",
          "app",
          "pipes",
          "io_thread"
        "locals": {
          "job": "None",
          "job_options": "None",
          "args": "[[{'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value'}]]",
          "io_thread": "False",
          "pipes": "None",
          "name": "'stats.get_data'",
        "filename": "/usr/local/lib/python3.6/site-packages/middlewared/schema.py",
        "lineno": 664,
        "method": "nf",
        "line": "                return await f(*args, **kwargs)\n",
        "varargspec": "args",
        "keywordspec": "kwargs",
        "locals": {
          "kwargs": "{'stats': {'step': 10, 'start': 'now-1h', 'end': 'now'}}",
          "args": "('***', '***')",
          "f": "<function StatsService.get_data at 0x81a007a60>",
          "clean_and_validate_args": "<function accepts.<locals>.wrap.<locals>.clean_and_validate_args at 0x81a007ae8>"
        "filename": "/usr/local/lib/python3.6/site-packages/middlewared/plugins/stats.py",
        "lineno": 115,
        "method": "get_data",
        "line": "            raise CallError('rrdtool failed: {}'.format(err.decode()))\n",
        "argspec": [
          "self",
          "data_list",
          "stats"
        "locals": {
          "err": "b'ERROR: realpath(/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd): No such file or directory\\n'",
          "proc": "<Process 96908>",
          "rrdfile": "'/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd'",
          "data": "b''",
          "i": "4",
          "names_pair": "[['disktemp-vtbd0', 'temperature'], ['disktemp-vtbd0', 'temperature'], ['disktemp-vtbd0', 'temperature'], ['disktemp-vtbd0', 'temperature'], ['disktemp-vtbd0', 'temperature']]",
          "defs": "['DEF:xxx0=/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd:value:AVERAGE', 'XPORT:xxx0:disktemp-vtbd0/temperature', 'DEF:xxx1=/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd:value:AVERAGE', 'XPORT:xxx1:disktemp-vtbd0/temperature', 'DEF:xxx2=/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd:value:AVERAGE', 'XPORT:xxx2:disktemp-vtbd0/temperature', 'DEF:xxx3=/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd:value:AVERAGE', 'XPORT:xxx3:disktemp-vtbd0/temperature', 'DEF:xxx4=/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd:value:AVERAGE', 'XPORT:xxx4:disktemp-vtbd0/temperature']",
          "stats": "{'step': 10, 'start': 'now-1h', 'end': 'now'}",
          "data_list": "[{'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value', 'cf': 'AVERAGE'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value', 'cf': 'AVERAGE'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value', 'cf': 'AVERAGE'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value', 'cf': 'AVERAGE'}, {'source': 'disktemp-vtbd0', 'type': 'temperature', 'dataset': 'value', 'cf': 'AVERAGE'}]",
          "self": "<stats.StatsService object at 0x819fedb70>"
    "formatted": "Traceback (most recent call last):\n  File \"/usr/local/lib/python3.6/site-packages/middlewared/main.py\", line 167, in call_method\n    result = await self.middleware.call_method(self, message)\n  File \"/usr/local/lib/python3.6/site-packages/middlewared/main.py\", line 1098, in call_method\n    return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)\n  File \"/usr/local/lib/python3.6/site-packages/middlewared/main.py\", line 1046, in _call\n    return await methodobj(*args)\n  File \"/usr/local/lib/python3.6/site-packages/middlewared/schema.py\", line 664, in nf\n    return await f(*args, **kwargs)\n  File \"/usr/local/lib/python3.6/site-packages/middlewared/plugins/stats.py\", line 115, in get_data\n    raise CallError('rrdtool failed: {}'.format(err.decode()))\nmiddlewared.service_exception.CallError: [EFAULT] rrdtool failed: ERROR: realpath(/var/db/collectd/rrd/localhost//disktemp-vtbd0/temperature.rrd): No such file or directory\n\n"
  "extra": null,
  "id": [
        "source": "disktemp-vtbd0",
        "type": "temperature",
        "dataset": "value"
        "dataset": "value"
        "dataset": "value"
        "dataset": "value"
        "dataset": "value"
Redcoat
Yarik
There have been quite a few reports of such behavior.
Recently Moderator Dru Lavigne commented to the effect that this was highly-hardware-dependent information and the next OS version would have some enhancements to improve what we are seeing.
Go here https://www.ixsystems.com/community/threads/freenas-web-gui-issues-missing-info.77551/#post-539214
Oh, thanks for your replay, just to figure out, by
you mean 11.3 or 12?
Redcoat
Per Dru Lavigne's posting - 11.3
