Cron not working
indivision
I am trying to set up a cron task that restarts a jail service every 6 hours. Here is the command:
jexec <jail_name> service <service_name> restart
When I run this code in the shell as root or click "Run Now" in the View Cron Jobs section, it works.
However, it doesn't appear to run properly on its own. The schedule looks to be ok because output is generated by the task right on schedule as expected. But, when I look at the service at those times, it is not affected.
I believe I have the settings right so that it sends output when there is an error. And I am getting output. But, its not informative error information. Here is what the output emails are:
usage: chown [-fhvx] [-R [-H | -L | -P]] owner[:group] file ...
	   chown [-fhvx] [-R [-H | -L | -P]] :group file ...
Any ideas about what is happening here and how to get this Cron task to run properly?
Thank you.
rvassar
That's the useage output for the "chown" command. So something is executing "chown" with options that it can't parse.
indivision
Thank you. The subject line of the email includes my cron task and I am receiving it on the cron task schedule every 6 hours.
It seems odd to me that chown would become involved with the command I have put in. But, maybe I am missing some factor here? Can someone confirm that is ok? Almost seems suspect...
I am running the cron task as root. Is that problematic somehow?
Chris Moore
Are you trying to edit cron files or are you setting this up in the GUI?
indivision
This is all set up in the GUI. I haven't touched the crontab directly.
rvassar
I have limited knowledge of how FreeNAS implements cron jobs via the GUI. Is this a GUI derived cron job, or something you've set up via ssh? It may be wrapping the "jexec" line in some kind of wrapper script, that it emits as a file at runtime, and then expects to "chown" to some user ID before executing. If that UID doesn't exist, or is misconfigured, chown would likely throw an error like that. But I'm kind of speculating here, and don't feel comfortable taking it any further than that. My expertise is traditional Unix/Linux, I'm still learning FreeNAS.
rvassar
indivision
It is a GUI derived cron job. I haven't touched the crontab file directly.
What UID does the jail run under?
root which is UID 0
I do seem to remember that FreeNAS does have a certain approach to the root account for security. So, maybe that is the issue?
rvassar
Inserting a root cronjob would be a security issue, so... It may be limited. But again, I'm at the end of my FreeNAS knowledge here. Under a traditional Unix/Linux system my next step would be to implement a regular cron job or even a script. By script I mean something that runs the command and then sleeps for 6 hours in an endless loop.
indivision
Ok. I would prefer to use the GUI cron setup. Should be a way to make it work.
Any ideas on what steps I would need to take to run the same task the same way but with a user with proper permissions? I'm a little thrown off on how that would work running cron on a service within a jail. Would I need to use a user that is also set up in the jail? Can I skip the top level permissions and use a user from the jail?
