Cron Jobs Stopping at 12pm?
noodlesuk
Hi All
Hopefully this hasn't been covered elsewhere, have had a search through the cron job posts and couldn't see a solution. I have a cron job setup to run a php script every 10 minutes, every hour, every day, every month, every day of the week. This runs absolutely fine from 0000 to 1200, then stops and restarts again at 0000.
I've checked the cron job file and seems all correct, have tried enabling and disabling. Running the job manually, after 1200, works fine? Is there something I'm missing?
Cheers
Sakuru
Please post a screenshot of your cron job task.
noodlesuk
Sakuru
Huh, weird. Which version of FreeNAS are you using?
Sakuru
Oh, that's pretty old. Try updating.
noodlesuk
Updated to 9.10, seems a lot better. Jobs now run, doesn't seem to stick to the interval set, but runs after 12 now. Thanks for your help.
Cheers
