CRITICAL: The volume himawari_vol (ZFS) state is UNKNOWN:
ardhy
Dear All Member,
today I have a problem that indicate ZFS vol not running well cause red alert mode on freenas
I tried to unplug the FC from storage and plugin again, nothing happened
for me its maybe happen due to the freenas can't mounting the volume
Environment:
Software Version: FreeNAS-9.3-STABLE-201412090314
Request Method: GET
Request URL: http://xxx.xxx.xxx.xxx/storage/zvol/create/himawari_vol/
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
  105.  response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
  156.  return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
  22.  return view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/storage/views.py" in zvol_create
  519.  vol_name=parent)
File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in __init__
  1542.  zpool = notifier().zpool_parse(self.vol_name.split('/')[0])
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in zpool_parse
  4307.  parse = zfs.parse_status(name, doc, res)
File "/usr/local/www/freenasUI/../freenasUI/middleware/zfs.py" in parse_status
  760.  status = data.split('config:')[1]
Exception Type: IndexError at /storage/zvol/create/himawari_vol/
Exception Value: list index out of range
anyone have an idea what the solution?
regard,
ardhy
I already solved the problem, i change my fiber optic
and then everything running well again,,
==closed==
