Newbie here. please help.
Alert CRITICAL: Device: /dev/ada3, 1 Currently unreadable (pending) sectors
OS: Current Train: FreeNAS-9.3-STABLE (Installed OS)
Zpool status seems okay, here it is:
smartctl -a /dev/ada3
]0;root@freenas:~[[1mroot@freenas[m] [1m~[m# zpp[Kool status
pool: OrgVol
state: ONLINE
scan: scrub repaired 0 in 6h35m with 0 errors on Fri May 15 08:35:34 2015
NAME STATE READ WRITE CKSUM
OrgVol ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/2ceb1ef3-85ad-11e4-a805-4439c494b325 ONLINE 0 0 0
gptid/2daf6dc8-85ad-11e4-a805-4439c494b325 ONLINE 0 0 0
gptid/2e70ff38-85ad-11e4-a805-4439c494b325 ONLINE 0 0 0
gptid/2f2d8157-85ad-11e4-a805-4439c494b325 ONLINE 0 0 0
gptid/2ff38ed2-85ad-11e4-a805-4439c494b325 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: none requested
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errorssmartctl -a /dev/ada3
]0;root@freenas:~[[1mroot@freenas[m] [1m~[m# smartc[K[K[K[K[K[Ksmartcl[Ktl -a /dev/ada3
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4NHZDPCJ4
LU WWN Device Id: 5 0014ee 2602a56fd
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri May 15 14:23:54 2015 PDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 241) Self-test routine in progress...
10% of test remaining.
data collection: (39900) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 400) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 25
3 Spin_Up_Time 0x0027 190 179 021 Pre-fail Always - 5466
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 72
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3651
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 72
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 60
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 54
194 Temperature_Celsius 0x0022 116 111 000 Old_age Always - 34
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 199 000 Old_age Offline - 15
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 3471 -
# 2 Short offline Completed: read failure 70% 3339 1564476880
# 3 Short offline Completed without error 00% 3339 -
# 4 Short offline Completed without error 00% 3338 -
# 5 Short offline Completed without error 00% 3337 -
# 6 Short offline Completed without error 00% 3336 -
# 7 Short offline Completed without error 00% 3335 -
# 8 Short offline Completed without error 00% 3334 -
# 9 Short offline Completed without error 00% 3333 -
#10 Short offline Completed without error 00% 3332 -
#11 Short offline Completed without error 00% 3331 -
#12 Short offline Completed without error 00% 3330 -
#13 Short offline Completed without error 00% 3329 -
#14 Short offline Completed: read failure 70% 3327 1564476536
#15 Short offline Completed: read failure 50% 3327 1564552088
#16 Short offline Completed without error 00% 3326 -
#17 Short offline Completed: read failure 40% 3325 1564642664
#18 Short offline Completed: read failure 60% 3323 1564478912
#19 Short offline Completed without error 00% 3323 -
#20 Short offline Completed without error 00% 3322 -
#21 Short offline Completed without error 00% 3321 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
