I have a FreeNAS system running with the following hardware:
FreeNAS-9.3-STABLE-201604150515
Intel Pentium CPU G3220 @ 3.00 GHz Dual-core Intel HD
Motherboard: SuperMicro MBD-X10SLL+ F-O UATX
Memory 16318MB (16GB DDR3)
Storage / HDs = (6) 3TB drives with
750 w Power Supply
OS Running from a USB stick mounted directly on the motherboard.
I believe its using RAID Z-2
As you can tell, I'm on an older version of FreeNAS. I would like to update to the latest version if my current system can support it. However I'd like to first address these alerts from the Alert menu:
I performed the first 2 commands from the article and here are the results of the test:
I need some direction and advice on how to solve the alerts. After the HD issue has been resolved, I would like to upgrade the OS to the latest version. Any direction on how to best accomplish this would also be great. Thanks in advance for you input and guidance.
750 w Power Supply
- CRITICAL: Device: /dev/ada3, 9 Currently unreadable (pending) sectors
- CRITICAL: Device: /dev/ada3, new Self-Test Log error at hour timestamp 42660
- WARNING: The 9.3-STABLE Train is now in Maintenance Mode. No new features or non-essential changes will be made. Please switch to the 9.10-STABLE train for active support.
- WARNING: New feature flags are available for volume media121. Refer to the "Upgrading a ZFS Pool" section of the User Guide for instructions.
[root@NAS-Server] ~# smartctl -a /dev/ada3 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red (AF) Device Model: WDC WD30EFRX-68AX9N0 Serial Number: WD-WMC1T1031262 LU WWN Device Id: 5 0014ee 602eae4f9 Firmware Version: 80.00A80 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Tue Apr 16 17:37:52 2019 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (39720) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 399) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 317 3 Spin_Up_Time 0x0027 184 176 021 Pre-fail Always - 5758 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 122 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 042 042 000 Old_age Always - 42668 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 113 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 70 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 51 194 Temperature_Celsius 0x0022 120 098 000 Old_age Always - 30 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 9 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 198 000 Old_age Offline - 27 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 42660 2286744854 # 2 Short offline Completed: read failure 60% 42345 1565516848 # 3 Short offline Completed: read failure 60% 42273 1565516848 # 4 Extended offline Completed: read failure 90% 42202 2739818888 # 5 Short offline Completed: read failure 10% 42129 1565516848 # 6 Extended offline Completed: read failure 10% 41875 1483231208 # 7 Short offline Completed: read failure 60% 41795 1565516848 # 8 Extended offline Completed: read failure 10% 41657 1483193496 # 9 Short offline Completed: read failure 60% 41576 1565516848 #10 Short offline Completed: read failure 20% 41384 1565516848 #11 Extended offline Completed: read failure 10% 41320 1143781384 #12 Short offline Completed: read failure 40% 41240 1565516848 #13 Short offline Completed: read failure 60% 41049 1565516848 #14 Short offline Completed: read failure 60% 40977 1565516848 #15 Extended offline Completed: read failure 50% 40909 2744268752 #16 Short offline Completed: read failure 60% 40833 1565516848 #17 Short offline Completed: read failure 60% 40641 1565516848 #18 Extended offline Completed: read failure 10% 40577 1484303448 #19 Short offline Completed: read failure 60% 40497 1565516848 #20 Short offline Completed: read failure 60% 40305 1565516848 #21 Short offline Completed: read failure 60% 40233 1565516848 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
