William Bravin
- Mar 16, 2016
Greetings to all
I just installed Truenas Scale as a VM on Proxmox on a dell r710.
this is a test environment that i am using to learn more and more about truenas and hypervisors.
Once this all will be working i will migrate this to an a r730
In setting the credentials to allow one of my truenas (core) servers to backup all my datasets to the 710
On all my turnas core servers the owner are UID wbravin and group wheel and it works. I can backup restore and moves files to my hearts content no issue.
I look at the credentials they show owner wbravin group wheel (which is correct)
in turenas scale I set the owner of the dataset to wbravin no issue, I set the group to wheel and save all fine
However when i go to datasets and look at the permission widget on the right called permissions i see the owner as wbravin however the group as root.
Thi is not correct the widget should show the correct owner (which i does) and the correct group ( which it doesn't)
Oh BTW i see that in truenas scale i cannot set the name of a dataset as two separate word ( ie. Tv Shows) i must set the name to TvShows
are these issues or am i missing a step?
Thank you
Thank you
