Creation of /mnt/mnt during 9.3 installation
corwin
Junior Member
I attempted to upgrade a 9.2 installation to 9.3-stable yesterday, and it hung partway through. I then followed the suggestion and did a clean install of 9.3. 9.3 found my volume with no problems, and once the system was up and reachable, I loaded my saved configuration.
Almost everything went fine. However, I have a immutable directory that has been created. tank is the name of my volume, btw.
/mnt/tank/<everything that should be here, including my jails>
/mnt/mnt/tank/jails/ - it looks like the 9.2 port and plugin warden template directories. This directory hierarchy is immutable, btw.
The /mnt/mnt/tank is NOT a zfs volume.
Also, the storage volumes web page shows tank->tank->tank/... Looking in the directory structure, there isn't two tanks, and zfs list doesn't show tank/tank.
These may or may not be related.
I would like to take a look at your system if you have time. Some other people have this problem and I want to take a closer look at it. Mind if I PM you and see about doing a remote session with you?
