cbray
- Jun 16, 2011
When making a ZFS Dataset there is a line to enter: Reserved space for this dataset:
I enter 100G. Later when I check via 'Edit ZFS Options' it is Correct and seems to work properly, it still shows 100G.
But on the following line for: Reserved space for this dataset and all children: I enter 50G. Later when I check it in 'Edit ZFS Options' it is blank. If I edit it then, the system seems to accept it and save it correctly.
Posted here because I'm a noob and couldn't find it elsewhere.
I don't think my hardware is the issue but I am running v8-BETA2-AMD64 on
ASUS P5G41T-M mobo
Intel E5400 CPU
4GB DDR-3
5 Seagate 500GB 7200 6GB SATA in RAIDZ
Pat-riot 2GB USB Stick
Thanks for ALL youins hard work
CB
ASUS P5G41T-M mobo
Intel E5400 CPU
4GB DDR-3
CB
