- Supermicro board, Supermicro Case
- 2 LSI 9211-8i Controllers
- 12 WD SATA 2 Terabyte Disks
- 2 Samsung S830 128 GByte SATA 6 GByte (for Cache)
- setting up from web-Gui several raidz or raidz2 volumes -> works well as long as only the WD 2 TByte Disks are involved
Problems
- only one SSD is shown in the web-gui, don't know command line to show more, tried severel setting in the LSI Bios,
- tried to connect one to the other controller, same result, in the firmware-Bios all disks are shown
- the LSI-firmware is updated to v11 IR, did not update to IT-Firmware, because I read here in this forum elsewhere, perhaps the SAS supermicro - backplane works not correct (not sure) with IT
- including the one SSD in a raidz-volume (I think zpool ist the correct name) shows a healthy volume but only a few Gigabyte capacity (eg. 476 GByte vs. 7,6 TByte (not the exact values, only relation))
- tried this with mark as "cache" (what is intended) or with "none" in GUI whith same result
- tried the 2 dd if=/dev/zero ... -lines found in this forum for each drive to "clear" them, but no other result.
- tried to create volumes or datasets on the above zpool with reservation '1t' gives me an error "out of space"
- editing disk-properties shows "auto" for the transfer-modus up to 3 Gbit/s (SATA 2) but no 6 Gbit/s, which should work for the samsum 830 SSDs
- tried not another SSD (which should be next try)
- any other ideas?
thank you
uwe
Problems
- any other ideas?
thank you
uwe
